Dana 80
Dana 80
Postby rockbuggy4x4 » Mon Jul 08, 2013 10:57 am
I was looking around the other day for wms-wms measurements for a Dana 80. Well, I found it and stupid me didn't write it down. And now I can't find it anywhere. I do remember reading that the C&C axle is shorter then the SRW, and the SRW is shorter then the pickup dually. Does anyone have the measurements? And also, are there Ford/Chevy Dana 80s with the 8x6.5 lug pattern? Can't really find any solid info on that either.
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Re: Dana 80
Postby Horus » Tue Jul 09, 2013 1:44 am
Are you just looking for a ring and pinion upgrade? If so...
http://www.pirate4x4.com/forum/axles-ti ... -70-a.html
From what I am to understand the Dana 80 has the same size wheel bearings as the 70 you already have. Sorry I've nothing to add regarding widths.
91.5 W250 Dodge 4X4 CTD. Getrag. DD Power pin removed, stock fuel cone back in. 366 spring. Power screw at stock depth. Stock turbo. Stock lift pump. Straight piped and Intercooled.
93 D250 Dodge club cab 2wd. All stock for now. Automatic.
Hard KOR Wheeler.
PNWJeep club member.
Horus
Re: Dana 80
Postby Mark Nixon » Tue Jul 09, 2013 9:47 am
I have all 3 versions here, C&C, SRW and Dually full bed.
All with drum brakes.
I may wander out in the heat to-day and get measurements.
Re: Dana 80
Postby CumminsPower59 » Tue Jul 09, 2013 10:35 am
Mark, is there any difference in the WMS for the D80 SRW with disc brakes vs. drum brakes?
Just wondering ;)
Re: Dana 80
Postby Mark Nixon » Tue Jul 09, 2013 11:17 am
I can't definitively answer that, since I don't have a SRW D-80 with disc brakes around.
I DO have a C&C D-80 with disc brakes that I can compare with the drum version.
I doubt they are any different, because both the disc and drum versions used the same wheels in 2001 and there were BOTH drum and disc in that year alone.
I suspect the same is true with the SRW version.
BTW, a 2nd Gen SRW drum brake D-80 is significantly wider than a 1stgen SRW D-70.
It locates the wheel/tire combo nearly even with the bed side.
Re: Dana 80
Postby rockbuggy4x4 » Tue Jul 09, 2013 12:28 pm
Horus- That's an interesting thread. But I'm hoping to put the D80 on my crew cab build, so no spool for me. :cry:
Mark- That world be greatly appreciated. And if you're ever interested in selling one, just let me know a price/condition/etc.
I'm pretty sure the D70 SRW is around 65.25" (or .75). The wms-wms should be the same weather its drum brakes or disc. The back plating/ flange where they mount to might be a little different though, but I'm not sure about that.
Jimmy
rockbuggy4x4
Re: Dana 80
Postby Mark Nixon » Tue Jul 09, 2013 1:36 pm
Okay, after a 20 minute sweat, here is what I found, keep in mind that I am also mentioning the years and drive:
C&C 2001, 4x2, disc brakes, 69.00 inches.
C&C 2000, 4x2, drum brakes, 68.00 inches.
SRW 1998, 4x4, drum brakes, 69.50 inches.
DRW 1998, 4x2, drum brakes, 72.00 inches.
These are axles of KNOWN origin, in that I either pulled them myself, or they were removed from vehicles that I saw before hand, not from some pile of axles somewhere.
I feel I am pretty close on these measurements, given that I did them with no tape holder and that I was sweating rivers while doing it. :mrgreen:
I find it interesting that the 2 C&C axles (Disc vs. Drum) are an inch different, given that the 2000/2001 DRUM brake C&C axles are called as interchangeable in the J/Y interchange.
Also note that the '01 disc and 1998 SRW drum axle are a mere 1/2" in width different, overall.
Re: Dana 80
Postby rockbuggy4x4 » Tue Jul 09, 2013 1:52 pm
Yea, that is kinda strange. Thanks for the measurements Mark.
Jimmy
rockbuggy4x4
Users browsing this forum: No registered users and 77 guests
