Coil spring ??
Coil spring ??
Postby Arnold Layne » Tue Aug 13, 2013 8:35 pm
Can I change out the coil springs without using a spring compressor, unhooking the lower ball joint and letting the spring down with a floor jack? '90 350
Arnold Layne
Re: Coil spring ??
Postby PToombs » Wed Aug 14, 2013 6:11 pm
I did mine with a floor jack. I can't remember if I unhooked the top or bottom joint though. I do remember I had to put the spring in, then turn it in to get it in the seat because it was tight. The lower seat where the spring sits has a notch because the spring doesn't have a flat end, the coil isn't tapered, it just stops. I think I had to use a ratchet strap or something like that to draw the control arms together to get the balljoint back in the hole too.
It was a few years ago, but I'm pretty sure that is correct.
Be careful Arnie! ;)
Re: Coil spring ??
Postby Arnold Layne » Tue Aug 20, 2013 7:31 am
Thanks Pete, I will be careful, I may get pissed and buy a spring compressor to help with the last inch or two.
Arnold Layne
Re: Coil spring ??
Postby PToombs » Tue Aug 20, 2013 5:16 pm
Good luck with that! Most of those are so cheap that they may not work. Have you actually looked close at how thick those springs are? :lol:
Users browsing this forum: No registered users and 77 guests
