Air bag repair?
Air bag repair?
Postby 93 W350 LE » Sun Sep 29, 2013 6:18 pm
Has anyone repaired a leakng airbag with success? Somehow the top mount has rubbed a hole in my passenge side front bag, can't afford to replace right now so I got a tire plug kit. Plugged it today and put 30# in the tanks. Guess we will see how it holds up.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
Re: Air bag repair?
Postby 93 W350 LE » Mon Sep 30, 2013 5:08 pm
So far so good, holding since yesterday. 60 miles round trip, with some dirt road.
Eric
93 W350 LE
Re: Air bag repair?
Postby 93 W350 LE » Wed Oct 02, 2013 3:26 am
FAIL!! Bag let me down yesterday afternoon. Will have to find the leak again, as the plug is still in place.
Amy suggestions, or is replacement the only option?
Thanks.
Eric
93 W350 LE
Re: Air bag repair?
Postby ellis93 » Wed Oct 02, 2013 4:36 am
Whenever the fords had just having problems with their air bags on Lincolns an such,there were companies that offered a repair service.....I know that may not be helpful info for your application but you could search that fact out and see how they repaired them
Re: Air bag repair?
Postby 93 W350 LE » Wed Oct 02, 2013 10:35 am
Anyone know how I can identify my bag or get a part # to replace it? All I know is it is a Firestone bag with about a 3/4" hose going into the top from a tank under my radiator core support. I know my rear set up is a Kelderman Compuride, but unsure of the fronts.
Thanks.
Eric
93 W350 LE
Re: Air bag repair?
Postby JimmieD » Thu Oct 03, 2013 1:33 pm
This is not based on direct experience - but it would seem to me you'd be better off to use a tire patch instead of a plug, or grind down the bit of plug that extends beyond hole and add a patch on top of it too? I imagine it would be difficult to apply pressure to patch while it cures but possibly you could wrap a cinch strap around the bag and tighten it down to press on patch while glue sets.
NAPA carries all sizes and types of tire patches, glue etc.
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
Re: Air bag repair?
Postby 93 W350 LE » Fri Oct 04, 2013 7:48 am
JimmieD wrote:This is not based on direct experience - but it would seem to me you'd be better off to use a tire patch instead of a plug, or grind down the bit of plug that extends beyond hole and add a patch on top of it too? I imagine it would be difficult to apply pressure to patch while it cures but possibly you could wrap a cinch strap around the bag and tighten it down to press on patch while glue sets.
I thought of that, but when you patch a tire the patch goes on the inside of the tire because the patch can't hole the pressure. That is why I thought I might be able to use a plug.
I might try the patch over the plug, just because there is really nothing to lose by doing it.
Thanks.
Eric
93 W350 LE
Re: Air bag repair?
Postby JimmieD » Fri Oct 04, 2013 12:07 pm
Of course on a tire with the patch inside the air pressure is pushing it against the casing, helping it to seal.
But that's sorta what I was thinking, nothing to lose. It will need some kind of tight tourniquet to cinch down the patch while glue cures. On my airbags I only run about 10-15 psi air pressure. Pretty sure a patch could handle that, even 20+ lbs, especially with a plug in there too.
'90 W-350 gasser...
JimmieD
Users browsing this forum: No registered users and 77 guests
