front spring hanger issues
Postby redneckmtrsprts » Tue Oct 01, 2013 10:17 pm
like the title said my front springs front hanger has wallered the hole out and I need to know can I repair this or just take and replace the hole assembly and drill out the rivets.
redneckmtrsprts
Re: front spring hanger issues
Postby simplysmn » Wed Oct 02, 2013 10:15 am
I would replace it yes it's going to be a Pain but much easier then trying to patch the old 1
simplysmn
Postby JimmieD » Thu Oct 03, 2013 1:08 pm
I've fixed spring hangers by welding a heavy washer, 3/16" - 1/4" thick on either side and using a longer bolt where necessary.
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
Postby redneckmtrsprts » Thu Oct 03, 2013 9:47 pm
how long has it lasted you with the washer repair
redneckmtrsprts
Postby JimmieD » Thu Oct 03, 2013 10:34 pm
Several years. I used good quality, made in U.S.A. Grade 5 or better washers, not common hardware store Asian junk. I've done similar on spring shackles too, or welded them, or made new shackles.
'90 W-350 gasser...
JimmieD
Postby Farmboy » Fri Oct 04, 2013 4:30 am
Mine were not wallered out too bad but bad enough that the rivets were loose, I simply took the rivets out and put slightly bigger bolts with washers. Held up for 4 or 5 years now..
Farmboy
Users browsing this forum: No registered users and 77 guests
