Half Ton Frame Questions
Postby cummins12club » Thu Nov 21, 2013 5:52 am
I bought a donor truck this past weekend to fix mine. After tearing mine apart I found that my frame looked like Swiss chesse from the cab back, so I doubt a nice solid club cab body and frame in North Carolina I picked up. This truck is a half ton and I can tell that the leaf springs and all the shackles look smaller then my old 3/4 ton stuff I'm curious if the actual frame itself is smaller/lighter. I'm trying to get down to 5000lbs so hopefully my new frame/suspension will help with that
cummins12club
Re: Half Ton Frame Questions
Postby RCCUMMINS89 » Thu Nov 21, 2013 11:05 am
Shackles are actually the same, the through bolts are smaller or bigger on certain models/years.
I think you'll be totally fine. There isn't much difference in the frames, if any. (talking gasser 1/2 vs the early 3/4 diesels)
Postby cummins12club » Thu Nov 21, 2013 4:26 pm
The rear shackle mounts are way smaller both sides of the springs, the springs themselves are smaller w less leafs (in rear) so I will save some weight there but the frames apear to be the same, will the gasser 4wd engine crossmember work or will I need to cut out my diesel one?
cummins12club
Postby RCCUMMINS89 » Thu Nov 21, 2013 4:40 pm
cummins12club wrote:The rear shackle mounts are way smaller both sides of the springs,
:?: New to me, I've never seen them of a different size. Learn something new everyday. 8)
