LSD Options for 1990 D250 W/3.07 Gears
Postby JeffTheMarine » Thu May 22, 2014 6:56 pm
I am interested in adding a LSD to my rear axle. I have a 1990 D250. From the information that I have I am assuming that I have a Dana 70-2U. I have read that the carrier is different for the axles with 3.07 gears which is what I have. So I am looking for a LSD that will work with this rear end. Thanks in advance for the help
Jeff
1981 Dodge W250 Crew W/94 12V&NV4500+NP205
Mods: Ground #100Plate,AFC Foot ground,BHAF
1990 Dodge D250 NonIC 12V Smoke screw flush,Fuel pin turned, Star wheel bottomed -5 clicks, fuel screw in 1 extra turn
JeffTheMarine
Re: LSD Options for 1990 D250 W/3.07 Gears
Postby Philip » Fri May 23, 2014 4:23 am
The 3:07 axle uses the same carrier as a 3:54/4:10. Just make sure on the spline count of your axles. These L/S can be found in 35 or 32 spline. Yours is most likely a 35 spline. But pull an axle to make sure.
Postby mknittle » Fri May 23, 2014 7:22 am
JeffTheMarine wrote:I am interested in adding a LSD to my rear axle. I have a 1990 D250. From the information that I have I am assuming that I have a Dana 70-2U. I have read that the carrier is different for the axles with 3.07 gears which is what I have. So I am looking for a LSD that will work with this rear end. Thanks in advance for the help
Jeff
If it has 3.07s it's a Dana 71. There are some minor machining differences to fit the 3.07s . I don't know about the carrier though.
mknittle
