Lost a fight with a snowbank yesterday - need fuseblock diag
Postby eyoung429 » Fri Jan 12, 2007 12:22 pm
Was cruising into work yesterday am. Small herd of deer in the road and I was going to go around them when my truck hit a patch of ice and plowed into a large snowbank and sunk.
Got her out last night with a frontloader...she fired up and drove fine but I have no turn signals nor brake lights....went out and got under the dash but can't read any of the markings on the fuseblock to do any backtracking...anyone have a pic or the layout of the fuseblock for a 1991 D350?
edited* no blown fuses
Thanks!!!
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Postby sdstriper » Fri Jan 12, 2007 2:30 pm
http://dens-site.net/Dodge_CTD/
This guy is the poop, I can't find it right now but he has the wiring diagram in pdf on his site or the DTR, you'll have to look and see if you can find it. I downloaded it but can't figure out how to extract it to use or share! Cripes....
sdstriper
Postby rlyons » Sat Jan 13, 2007 6:49 pm
Check the plug behind the rear bumper and see if the snow unplugged it. Could also be a plug in the wiring harness that runs from the front to the rear. Just a thought. :wink:
92 D250 Club Cab 4X2, 5 speed, ASA Modifieds Intake, Jannetty Racing Team Exaust System, Tweaked Pump, 3200 RPM Governor Spring, HTT Stage III Turbo w/16cm2 , Pyro/Boost/Tach Guages, Power Wagon Injectors, KDP Tabbed, Borgeson Steering Shaft.
rlyons
Postby eyoung429 » Tue Jan 16, 2007 11:19 am
Well, I must have hit that snowbank harder than I thought....
Got under the dash and appearantly I kinda crunched the fuseblock but didn't notice till I unbolted it from the fw to work on it. :(
Now looking for replacement but I do have my lights functional for the time being.!!!!!
Thanks guys!!!
eyoung429
Postby sdstriper » Sat Jan 20, 2007 12:43 pm
Alrighty then, I found it again! :D
http://dens-site.net/Dodge_CTD/1991.5-Wiring_Diagrams/
My hats off to Den for putting some of things he has online.
sdstriper
