rear disc conversion
Postby IowaCummins » Wed May 27, 2009 6:41 pm
ok guys both front and rear brakes went to crap today adn im wondering abotu the rear brakes. i have been reading alot of forums about it and im just wondering if anyone has dont it on here? i want to keep my parking brakes so i have to use 77-78 cadilac eldorado calipers. guys say to use 82-95 f250 diesel rotors. so i found a website that has a kit that has brackets, rotors all in one kit minus the calipers. here is the web site.
http://tsmmfg.com/2680L.htm
what do you guys think of this?
IowaCummins
Postby RumbleFish » Thu May 28, 2009 7:30 am
when i put rear disc on my ramcharger (with dana 60 rear axle) i used a kit from ebay that came with everything. the rotors and calipers were from a 78-ish chevy K20. the caddy calipers are the same but with parking brake provisions. ive never heard of using the ford rotors, so i dunno.
my kit was $300 shipped and came with everything. ive always thought this streetrod place was overpriced. you can find the brackets on ebay and buy the rest from a parts store, and maybe save a few bucks.
Postby Bogie » Thu May 28, 2009 9:41 pm
I used Ebay brackets from GreatLakesOffRoad and K20 rotors & calipers as I didn't want caddy calipers I went to a driveline parking brake setup.
1984 Dodge W350 Crew Cab 9"Lift 37" SSR's 360/NP435 D60's W4.10's
1966 Dart 273HP 4Speed 3.90's Radio/Heat Delete
Bogie
Postby BC847 » Sat Jun 06, 2009 11:00 am
I did an install of a similar kit using the Eldorado calipers so as to keep the PB. It too uses modified Ferd F250 rotors. If I remember correctly, the inside diameter is bored out to fit the DANA70/60 hub, and the stud holes are enlarged to fit our studs. They work very well.
You can read about the install here ~ http://www.dieseltruckresource.com/dev/ ... l?t=146673
