constant death wobble
Postby VEfreak » Mon Oct 26, 2009 2:07 pm
Hey guys, truck is in some serious trouble. I had been having a problem with my truck were it would death wobble between 40 and 50 miles and hour while coasting, but it only did this sometimes. I bought a set of used tires and put them on. Then it started death wobbling when it hit 40mph all the time. I put the old set back on exactly how they were, same problem. Can anybody offer me some advice? Tie rod ends seem ok, no noticeable play.
I AM ZUES DAMNIT
VEfreak
Postby PToombs » Mon Oct 26, 2009 5:56 pm
Have a steering damper?
Have you checked the front wheel bearings? If they're loose, it can cause this too.
Have you tried to swap wheels around between the set on the truck? (on my 97 I had a bad death wobble experience and it shook all the time after that. I swapped it from LF to the RR and could still feel it shaking back there. It F'd up the tire bad)
Postby TTipswprd » Mon Oct 26, 2009 8:22 pm
i would check your tie rod ends. grab your tie rod. if you can move it the replace the ends
TTipswprd
Postby Mark Nixon » Tue Oct 27, 2009 7:12 am
Is it a 2 wheel drive?
If so, look at ALL of the jointed areas on the solid crossbar, especially the idler arm and pitman arm areas.
The pitman and idler arms may seem tight, but they have a bad propensity of ovalling out the hole that the taper passes through.
Take the nut off, separate the joint (if it falls loose, there's your answer) and look for wear around the tapered hole.
Check all of the upper and lower ball joints.
Also, check the steering shaft coupler on the steering box, very common for it to go bad, too.
Basically check EVERYTHING that can be a loose point and if you don't know how to do it, go to a truck shop that does DOT inspections, I GUARANTEE they can tell you where it's loose at.
Best way I have seen to check "floating" joints like tie rod ends and idler/pitman is to squeeze the joint in a large pair of channel lock pliers, if it moves noticeably, it needs replaced.
Balljoints are checked by jacking up the lower control arm, away from the lower balljoint, and using a bar to try to move the balljoints around, anything over @ 3/16" in any direction is too much on lowers and uppers.
DON'T FORGET TO CHECK THE FRONT BRAKE ROTORS AND BEARINGS FOR EXECESSIVE WARPAGE AND BEARING PLAY!
Postby VEfreak » Tue Oct 27, 2009 11:15 am
the brakes are damn good. It's a W-250.
I AM ZUES DAMNIT
VEfreak
Postby Mark Nixon » Tue Oct 27, 2009 12:25 pm
2wd or 4wd, the same applies.
Check every place it could be loose.
Postby rmauto1 » Fri Oct 30, 2009 10:57 pm
My truck used to death wobble, the pitman arm was loose, and the pre load in the gear was loose. tightened them both up and it was good to go.
rmauto1
Postby VEfreak » Sun Nov 01, 2009 11:29 pm
Was able to poke around my truck this weekend. The frame and steering box bracket were cracked. Welded them and that fixed alot of the problem. Front leaf bushings are dust, gotta replace those. The coupling and the steering shaft and gear box seems worn too. Pit Arm and drage link also seem tired, but I need to get the right puller to seperate them. Tie Rod is good though.
I AM ZUES DAMNIT
VEfreak
Postby PToombs » Mon Nov 02, 2009 6:34 pm
VEfreak wrote: Tie Rod is good though.
Well that's something good! ;)
Postby VEfreak » Mon Nov 09, 2009 3:47 pm
I took off the cap of my steering knuckle. The tapered bushing seems pretty damn worn. It's worn into an oval. I suppose that could be a contributer to my death wobble.
I AM ZUES DAMNIT
VEfreak
Postby cougar » Sat Nov 14, 2009 9:59 am
:popcorn:
01 2500 "the work truck".
cougar
Postby VEfreak » Fri Nov 20, 2009 3:28 pm
Got the cone bushing in. Fixed alot of the problem, but there is still a tiny shake 50-55 MPH. Not deadly but it is still the. Gonna put on a steering damper and have it aligned.
I AM ZUES DAMNIT
VEfreak
