GASSER 1 ton 4X4 t-case and axles?
Postby Mark Nixon » Wed Dec 09, 2009 5:16 pm
Found a '91 1 ton 4x4 with a 360 gas and an auto.
Are the front and rear axles and t-case the same as the Cummins automatic pieces?
Re: GASSER 1 ton 4X4 t-case and axles?
Postby bgilbert » Wed Dec 09, 2009 5:54 pm
Mark Nixon wrote:Found a '91 1 ton 4x4 with a 360 gas and an auto.
If it's a true 1 ton, it most likely will at least have the 1 ton front axle, the Dana 60f. Look for king pins on the D60f, ball joints on the D44f. The rear could either be a D60 or D70. The transfer case if a np205 will be the same as the diesel auto t-case.
Bill Gilbert
bgilbert
