Traction Bars
Traction Bars
Postby CaseyF » Sat Mar 19, 2011 9:59 pm
Does anybody have any pics of their traction bars, or any tips or tricks to building them? I plan on building a set my self.
1992 W350 flat bed. GlowShift Gauges, 3.54 gear, Full Power Screw bottomed, DennyT Pump Top Delete, 366 GSK, Custom CAI, Pro Comp fuel pump, DE 4'' Exhaust, 14cm Exhaust Housing, Getrag.
CaseyF
Re: Traction Bars
Postby ahale2772 » Mon Mar 21, 2011 5:14 am
check out ruffstuffspecialties for some nice parts. I got tabs, heims and weldable pipe ends from them
Re: Traction Bars
Postby flyinredneck » Tue Mar 22, 2011 10:08 pm
do you think that i will neeed traction bars with like 375 to 500horses
1992 w250 stock straight pipe with pump a lil tweaked denny t stage 2 fuel pin fuel screw at 3 turns
flyinredneck
Re: Traction Bars
Postby CaseyF » Tue Mar 22, 2011 11:03 pm
Do you have a picture of your traction bars, Ahale?
CaseyF
Re: Traction Bars
Postby ahale2772 » Wed Mar 23, 2011 8:34 am
yes two very crappy pics from an old post...
viewtopic.php?f=10&t=8724
i didnt get a good one of the rear, its just a set of tabs sticking down off the ubolt plate.
you can see the front crossmember I made, i welded the tabs on the top because the bars matched the driveshaft angle better. BUT, Id say the truck sits about 6inches higher than stock so your truck may be different
Re: Traction Bars
Postby CaseyF » Wed Mar 23, 2011 8:52 pm
What kind/size of tubing did you use? I like your stack, I plan on geting one on mine soon.
CaseyF
Re: Traction Bars
Postby ahale2772 » Thu Mar 24, 2011 6:11 am
well the tubing I used first....before I bent them to banannas...was some rollbar tubing I had laying around, dont think they would have bent if I had not abused them like I did (pulled in the 8000lb class with a bit over 6500lbs)
I have now remade them with 1inch ID dom chromolly stuff I got from a power substation, but havt put them on yet because Ive got no need of them commuting to work everyday.
I like the stack too :grin: its just the right size, just the right sound
Re: Traction Bars
Postby CaseyF » Thu Mar 24, 2011 9:59 am
I can't ever get pics to show up right here.
CaseyF
Re: Traction Bars
Postby ahale2772 » Thu Mar 24, 2011 12:06 pm
that one showed up ok, love the black dually's with the chrome center, thats the only way to do it
Re: Traction Bars
Postby CaseyF » Thu Mar 24, 2011 8:38 pm
It doesn't show up as a whole picture on my computer, just from the back of the door back.
CaseyF
Re: Traction Bars
Postby Tacoclaw » Sun Mar 27, 2011 8:07 am
Mine does the same thing, Casey. I just left click and "view image". It's a slight hassle, but I don't feel like fighting my computer to get it to display right. :lol:
Re: Traction Bars
Postby Beattyr87 » Tue Mar 29, 2011 7:26 am
casey where did you get your center caps or are they just regular old ones you get from anywhere. also when it comes to traction bars is there any angles or measurements that have to be a certain way or can i make the angles whatever i want them to be. my truck is lowered i think they pulled leafs out but idk. if that makes an difference. finally should i go ahead with traction bars or bite the bullet and rip everything out and bag it.
Beattyr87
Re: Traction Bars
Postby ahale2772 » Tue Mar 29, 2011 9:17 am
the best method is to try and match your bars to the same angle as your driveshaft (under load is best), keeping your pinion angle as straight as possible is best (I cranked my bars in when pulling to bring the pinon angle up)
some say the bars should be no longer than where the driveshaft meets the t-case
Re: Traction Bars
Postby CaseyF » Sun Apr 03, 2011 7:20 pm
Sorry its been a while since Ive got on here. I got center caps and simulators on ebay a while back, and I wanted something different so I painted the wheels black. The center caps are like stock ones but my front ones arent cut out for 4x4.
CaseyF
Re: Traction Bars
Postby CaseyF » Sun Apr 03, 2011 7:26 pm
CaseyF
