dana 44 front driveshaft to NP205 Compatible???
Postby Collers9640 » Thu Apr 07, 2011 12:32 pm
will a front drive shaft out of a 90 W250 (gas truck) with a dana 44 fit a in my 91 cummins
Collers9640
Re: dana 44 front driveshaft to NP205 Compatible???
Postby josh_6bt » Tue May 24, 2011 1:09 pm
The CV end should bolt up, however the u-joint at the pinion may be different. Also depending on what trans and t-case are in the gas W250 it could be a different length compared to yours.
1992 W250 EC, 5 speed, 3.54s, 175hp p-pump, timed @ 16.5, #100 fuel plate, 4k GSK, 5x14, .024 DV, head studs, 60lb VS, 4" exhaust, BHAF, cooler tubz.
josh_6bt
Postby Mark Nixon » Sun May 29, 2011 10:45 am
The D-44 shaft will definitely be longer.
Also, chances are very good that the pinion flange on the D-60 is the same, as most D-60s used the 7260 U-joint, but there were a few built with a 7290 joint.
I've never seen any difference between the 2 on the CV end of it.
