Axle hub oil leak
Axle hub oil leak
Postby cougar » Mon Apr 25, 2011 7:20 am
I have oil leaking from a strange place on the rear differential. It is leaking from between the drum and the hub flange it attaches to. Had them leak from the lip seal and the gasket on the drive axle flange, but never there. Cracked?
01 2500 "the work truck".
cougar
Re: Axle hub oil leak
Postby PToombs » Mon Apr 25, 2011 5:18 pm
It's possible. Have you checked the vent to make sure it's not plugged?
Postby ellis93 » Mon Apr 25, 2011 6:03 pm
My 93 has metal shields that direct oil to where you say yours is leaking. They stick out just enough to catch the gease.
Postby cougar » Wed Apr 27, 2011 2:06 pm
I'm afraid I'm not so lucky. It's cracked :grrr:
cougar
Postby PToombs » Wed Apr 27, 2011 5:53 pm
Weld 'er up! :grin:
