fliping leaf shackles
Postby flyinredneck » Mon May 09, 2011 12:30 pm
has anyone done a shackle flip
ifso how do you do it?
1992 w250 stock straight pipe with pump a lil tweaked denny t stage 2 fuel pin fuel screw at 3 turns
flyinredneck
Re: fliping leaf shackles
Postby BILTIT » Mon May 09, 2011 1:11 pm
See here:
http://ramchargercentral.com/jungleshdd ... g4esq0k7e3
I have done it on an chevy but not a dodge, same deal though.
Derek B.
BILTIT
Postby flyinredneck » Mon May 09, 2011 9:59 pm
i thought you could do this for free
flyinredneck
Postby BILTIT » Tue May 10, 2011 5:50 am
You can but it isn't as pretty or strong.
http://coloradok5.com/shackleflip.shtml
Derek B.
BILTIT
Postby Fred_M1010 » Wed May 11, 2011 4:12 am
Or find a front springhanger with the same distance between the spring and the frame, and beef it up some.
Maybe not pretty, but plenty strong:
http://coloradok5.com/forums/showthread.php?t=256348
(See fourth post)
-91.5 W250
Fred_M1010
Postby flyinredneck » Wed May 11, 2011 10:35 pm
how much lift do i get
flyinredneck
Postby Fred_M1010 » Thu May 12, 2011 12:08 am
Same as the length of the shackle.
More if you use a hanger that lowers the shackle mount
-91.5 W250
Fred_M1010
Postby flyinredneck » Thu May 12, 2011 10:11 pm
have you done it?
flyinredneck
Postby Fred_M1010 » Fri May 13, 2011 1:25 am
Yes, it's my build thread I posted a link to in my earlier post.
Btw If you want you can tweak the shackle angle for maximum flex (move the hanger forward).
You'll get slighty less lift though...
If I was lazy I would do it like they did in the second link Biltit posted, but weld some reinforcement tying the outer part to the top of it
-91.5 W250
Fred_M1010
