Exhaust hanger at the transmission?
Postby Fred_M1010 » Wed May 11, 2011 4:22 am
My truck has begun to make a really disturbing noise from the exhaust system.
It looks like there should be some bushing-like hanger bolted to the transmission...?
But the rubber is gone on mine...
I can't find anything like it at rockauto.com
Does anyone have a part-number or should I just remove it and come up with something else...?
-91.5 W250
Fred_M1010
Re: Exhaust hanger at the transmission?
Postby ciamcoop » Thu May 12, 2011 2:32 am
When I installed my 4" system I couldn't get things to line up with that bracket so I left it off. Haven't had any issues without it, so that's an option. I don't have a part number.
'93 W250LE 4x4 club cab, getrag, denny t, 366 spring, 181/210 cam, bored. 020, KDP, 5x.014's, piston pump, 4" tbe, cold air, 255/85/16s, 3.54's one wheeler peeler
ciamcoop
Postby 1arock » Thu May 12, 2011 6:24 am
You need to figure out a way to hook that bracket on the trans up. Without it the next hanger in the exhaust system is at the muffler, and all the weight of the piping is on the turbo outlet flange. Sooner or later either the clamp, down pipe, or turbo flange is gonna give it up and then you will have a bigger mess imo. Rocky
92W250 w/a 68D100 skin,tach, pyro, boost, trans temp guages, rebuilt a518 w/a PTC converter, 4in muffeled exhaust, 3200 gov spring, he351cw,M@H dynamic timing, 5x12s,M@H M3 pin, pump jacked with, 3.54s, 6+ lift, 14.5x36r rubber,nearly done,"What was I thinking?"
1arock
Postby Fred_M1010 » Fri May 13, 2011 6:22 am
Fixed it!
I found an old rubber hose that I used instead of a bushing.
It fitted perfectly after some pursuasion 8)
-91.5 W250
Fred_M1010
Postby PToombs » Fri May 13, 2011 6:13 pm
Good job Fred! Keep an eye on it to make sure the hose doesn't burn up with the heat.
I used my stock bracket with my 4" pipe, IIRC I trimmed the side so it would swing out a little farther away from the bell housing.
