92 w250 parking brake
Postby 1arock » Thu May 12, 2011 10:06 am
I need help figuring out the parking brake cables on my truck. I have all three cables but nothing to connect them together. the rear cables are fastened to the frame bracket, the front cable has a long threaded rod on the end of it. What does the parts that connect these together look like. the rear cables are different lengths. All three cables are new. I never had these parts they were missing when I got the truck. The fact that the the rear cable ends don't line up makes me think it might be something Dodgy or special. thanks Rocky
92W250 w/a 68D100 skin,tach, pyro, boost, trans temp guages, rebuilt a518 w/a PTC converter, 4in muffeled exhaust, 3200 gov spring, he351cw,M@H dynamic timing, 5x12s,M@H M3 pin, pump jacked with, 3.54s, 6+ lift, 14.5x36r rubber,nearly done,"What was I thinking?"
1arock
Re: 92 w250 parking brake
Postby Fred_M1010 » Fri May 13, 2011 6:29 am
Does this help?
-91.5 W250
Fred_M1010
Postby 1arock » Fri May 13, 2011 7:27 pm
Yes that does, I can make something like that. Thanks Rocky
1arock
