steering shaft
steering shaft
Postby hassy21 » Fri May 20, 2011 10:25 am
Hey just wondering if anybody has put a u joint on there stock shaft to get rid of that stock junk that always needs to be replaced. Just wondering where to get the joint,part number and specs like what the spline number is. Thanks just trying to get my steering to feel more solid since lift.
hassy21
Re: steering shaft
Postby BILTIT » Fri May 20, 2011 1:09 pm
Derek B.
BILTIT
Re: steering shaft
Postby hassy21 » Fri May 20, 2011 2:00 pm
Would love to get that borgenson shaft but can't afford it just want to get the joint itself that welds to stock shaft and has splines on other end.
hassy21
