Front Axle
Front Axle
Postby collegekid » Fri May 27, 2011 10:37 am
What is the reason for switching the front axle on the 4WD truck from having the diff. on the passenger side, to moving it to the driver side, all the new trucks on the road its on the driver side, is this just to make the linkage to the tcase easier to mount on the driver side of the Tranny hump, or is there a different reason?
collegekid
Re: Front Axle
Postby oldestof11 » Fri May 27, 2011 12:19 pm
The only thing I can think of is the exhaust. Good luck with getting anything bigger than 4" past the T-case. Massage the cab and frame for 5".
Re: Front Axle
Postby cougar » Sun May 29, 2011 7:24 am
Some one got a cheaper deal that way.
01 2500 "the work truck".
cougar
