How Much Payload Before the Springs Go Flat?
Postby Relentless » Tue May 31, 2011 7:12 pm
I've got a '92 Dodge 2wd 1 ton Cummins dually with overloads on it. The rear main leaves have 8 leaves, totalling 2 3/4" thick, the overloads are 5 leaves, thickness of 1.5 inches. I've got a line on some heavy scrap iron, but I'm not sure how much weight I can put in the bed before the springs go flat. All springs are in good shape, still have good arch. Any ideas?
3k spring, Hx35, NV4500, BHAF, KDP Fix, fuel pressure gauge, ISSPRO boost gauge & pyro, still 3" straight piped, homemade 4.5" intake tube, silencer ring, homemade 5"x5"x3/16" 5 MPH bumper, stock injectors, 3/16" timing advance, 633k miles, and more to come!
Relentless
Re: How Much Payload Before the Springs Go Flat?
Postby bgilbert » Tue May 31, 2011 7:20 pm
Relentless wrote:I've got a '92 Dodge 2wd 1 ton Cummins dually with overloads on it. The rear main leaves have 8 leaves, totalling 2 3/4" thick, the overloads are 5 leaves, thickness of 1.5 inches. I've got a line on some heavy scrap iron, but I'm not sure how much weight I can put in the bed before the springs go flat. All springs are in good shape, still have good arch. Any ideas?
As long as your bumper is not touching the ground, you should be ok IMO. ;) I'd be more worried about your tires. You have plenty of leafs so they'll take some weight. I'd say 2-3 ton before going flat.
Bill Gilbert
bgilbert
Postby Richie O » Tue May 31, 2011 7:44 pm
What ever looks good. I have seen 1 tons with 10 tons of payload go across the scales.
Postby Tacoclaw » Tue May 31, 2011 7:48 pm
Yup, it honestly depends on your tires more than anything.
Now, if you're going to be hauling it any sort of distance, you might want to take it easy, but with a pretty local haul you can get pretty wild. Just try to make it as smooth as possible, lots of stress on your frame and stuff when the only suspension is the bumpstops.
Oh, and make sure you're aware of any DOT guys running around. No matter how careful you're being, they won't care.
Postby Mark Nixon » Tue May 31, 2011 7:54 pm
I had 3 ton (6,000 lbs) of scrap, with high sides on the old flatbed, a while back and it pulled it like it was barely an issue.
The SPRINGS taking it, that was another matter.
This thing was built as a welding rig and has a very heavy flatbed on it and the truck has been heavier than I've had it, because the overload strikers are bent by about an inch, ON ALL 4. :shock:
I know it's overloaded for the dead springs when I hook the 2-car to it, because it's actually at the already-bent overload strikers, when it's loaded with 2 fully dressed mid '70s GM fullsizes.
It's scaled right at 25,000 before, overweight on both trailer and truck, but the Cummins just keeps moving it.
Even with the brakes the flatbed has, slowing/stopping it all is a whole 'nother matter. :roll:
Postby pulltilbroke » Tue May 31, 2011 10:50 pm
Load it like a rail car and drive it like a race car. :D
Postby Relentless » Wed Jun 01, 2011 3:53 pm
Thank you for the advice guys! The distance I need to travel is about 100 miles, but when I'm hauling a load, I only go about 45-50 mph. Better safe than sorry :).
Relentless
Postby Richie O » Wed Jun 01, 2011 4:03 pm
As said before, they will tow way more then they will stop.
