I would like to change my wheel setup. I was wondering if anyone has experience with this. Can I run a single rear wheel on the rear on my dually axle. I would like to run some 20" wheels from a 2500 chassis. This way I can run a 35 inch tall tire and keep this truck in the range of the VE pump for the 1/4 mile. Plus they wheel selection is fantastic...
When I ordered new rotors they had the same part number as the 2500 rotors. Mine have an adapter or spacer bolted to the outside of the rotor to run the dually front wheel. Anyone know if its possible to remove this spacer and get a rim with less backspacing and run a single 20" up front...
I never took the rear wheels off, can I remove the rear outside wheel and hub? and run a 12" wide rim with some big meats?
Thanks
