Axle Diameter on Dana 60?
Postby ryanihf250 » Mon Aug 13, 2007 5:11 pm
I have a 92 D350 with the Dana 60 I suppose. I found a 60 on the front axle, but how do I definatley tell? I need the axle dia. to order some ladder bars. I want some L&L ladder bars but they have the axle diameter. I am trying to order them from National Tire and Wheel. I measured myself and it was 11in around the back axle tube. The salesman said that there was no way, so i guess i am a dummy and can't measure it right. He said that he thinks that it should have a 3 1/2in axle diameter on the 60.
Thanks for any help
Ryan
Playtoy:1992 Dodge 350 4x4 SRW Cummins. 6in lift, 35in Pro Comp X , Dana 80 swap 4:10 Pump maxed, BHAF, 6x16inj, 3200 GSK, Piston Lift Pump, II SPS turbo.Street Pulling truck project. www.libertyantiquetractorpull.com
ryanihf250
Postby Philip » Mon Aug 13, 2007 8:55 pm
Your truck should have a 70 axle under the rear. If it has a 60 someone put it there Dodge didn't.
The measurement they need is the dia of tube is not the outside radis.
I can throw a tape on mine tomorrow for you.
Postby KTA » Mon Aug 13, 2007 11:24 pm
You guys and your geometry wow!! Quick lesson on circles.
Circumfrence = distance around
Diameter is distance across
Radius is from the center out or half the diameter
Circumfrence divided by PI or 3.141592654 = Diameter
That means your 11" circumfrence axle is 3.5" Diameter :P
