Can AC compressor be moved back a little? Belt problem
Postby Diesel » Sat Jul 02, 2011 2:12 pm
So my belt is getting cut by the AC compressor pulley because the compressor pulley is too forward. Can the compressor or the pulley be moved back?
1991.5 D250 Intercooled A518
Diesel
Re: Can AC compressor be moved back a little? Belt problem
Postby Tacoclaw » Sat Jul 02, 2011 3:34 pm
Don't know the exact routing, but make sure an idler or tensioner isn't going bad and making the belt track outward. If I remember right, the compressors are bolted straight to their bracket.
Postby collegekid » Sat Jul 02, 2011 3:55 pm
Compressor is mounted into the bracket on the block, its either the tensioner right above it, the fan assembly (4 10mm bolts behind the fan) or the crank pulley could be loose and coming off (4 15mm bolts), check the alternator pulley too
collegekid
Postby Diesel » Sun Jul 03, 2011 6:39 pm
It's so weird how the pulley sticks out on the ac and thus cuts the sthi out of the belt. I'm tempted to just buy a belt with fewer ribs and run that.
Diesel
Postby collegekid » Sun Jul 03, 2011 7:36 pm
how many ribs is yours running, and is the compressor a new one, or has it been doing this
collegekid
Postby Diesel » Mon Jul 04, 2011 9:33 pm
I'm running the stock belt. The compressor came on it and the original belt was also torn. Could I have the wrong compressor?
Diesel
Postby collegekid » Tue Jul 05, 2011 10:26 am
ya, thats a possibility, can you see a part number on it
collegekid
