Cracked frame and power steering box mount
Postby mhuppertz » Sat Aug 18, 2007 2:10 pm
Anyone know where I can get a power steering box mounting bracket? Mine is about to split in half!
mhuppertz
Postby 2muchtq » Sat Aug 18, 2007 5:23 pm
Dealership. Bout 30$
2muchtq
Postby moab4x4 » Tue Sep 18, 2007 11:39 pm
Dodge had a brace to the front crossmember in the 70's if you can find one in a junk yard. 4x4 trucks and RC's
It would probably make the new brace last longer. If your brace is broken, check the frame. It cracks next and will need to be repaired. Some weld it, some plate the back, some box the frame.
Mine is welded for the second time and I think I will either install hydro assisted steering or buy a repro brace from:
http://www.dodgeconnection.com/catalog/ ... 541374.htm
Good luck and check that frame closely, especially around the front mounting bolt (if you are 4x4)
Ken
92 W350 LE Getrag, 3.54, 4"/2" lift,
HTT Stage II, POD's, 4", PDR cam, KDP, 3200 GSK, Pin ground, Keyed Valet
Pyro, Boost in Message Center, Isspro tach, Damplifier-ed entire cab! Dual Batts, Keyless Entry, LED's in dash
moab4x4
Postby mhuppertz » Wed Sep 19, 2007 5:29 am
I got one from the dealer for $22. My frame is cracked badly in front of the box mount, so I will be welding the heck out of it.....
I looked at the brace, can't figure out how it mounts???
mhuppertz
Postby Bookshelf » Thu Sep 20, 2007 1:38 pm
The part that sticks out bolts onto the front crossmember, triangulating that corner. I'm ordering that brace for my current truck, which has a perfect frame and bracket. I want it to stay perfect. I can't even remember how many cracked frames, loose spring hanger rivets, and cracked steering box brackets I've seen on these trucks.
91.0 W250 Auto
90 Chevy V30
Bookshelf
Postby Miklos » Mon Oct 01, 2007 8:14 am
Just replaced one on my wifes daily driver (why is the steering wheel all the sudden in a different stop?). It was $18 + tax. New parts guy had a hard time finding it in lookup, but the part number for a 92 w250 is 52037876.
Miklos
Postby JAyers » Thu Mar 20, 2008 5:17 pm
Will this brace work for a 4x4? My frame is cracked bad. When you turn the wheel to the left, the steering gear moves 1/4in.
93 W250...balanced, ported, and fresh. Equipped with 14mm h/r, A1000 supply, Hamitons 188/220, T4 stainless manifold, s360/68/.91ar - s475/74/1.1ar twins, and Kennys dd clutch.
JAyers
Here's an idea...
Postby Ace » Fri Mar 21, 2008 5:53 am
Mine wasn't bad - yet - so what I did was get a new brace, bolts, and basically mount/weld it in behind the frame and gusset it down to the crossmember like this:
http://stuff.is-a-geek.net/PhotoAlbum/C ... TD_120.jpg
Ace
Postby jensenkennels » Fri Mar 21, 2008 7:16 am
Plan B - http://rockcharger.com/rcs/rockcharger/crossover2.html
You will NEVER break this.
MADDOG
jensenkennels
Postby cummins king » Fri Mar 21, 2008 7:30 am
ya that would be very hard to break
93 4X4 auto
cummins king
I beg to disagree...
Postby Ace » Fri Mar 21, 2008 8:34 am
He left out the gusset. That's basically what I did, except using a OE brace for the boxing portion and stitching it in, instead of full seam welding. The gusset down to the crossmember is the key piece that provides the structural rigidity to prevent the frame from cracking under stress. There is nothing supporting the frame laterally against the steering box. It may just crack at the ends of his welds.
But that boxed portion sure never will break!
Ace
