rear diff bearing and seal #'s
Postby manyholes » Sun Jul 17, 2011 5:41 pm
hey guys , lost an oil seal on my trip thru bc these past few days on the rear hub, figured might as well throw some new bearings in there while i change the seal, anybody have the seal/ bearing numbers??? i can order the parts from the parts store off the truck info but if i have my numbers, i get a big discount at comercial bearing but they cant look up vehicle numbers. ive tried and so have they. thanks guys. im gonna change the inners, outters and ill check the races. also any opions on who makes a better oil seal?? ive used a pile but comercial deals with national and timken, i dont use nothing but timken bearings. never got opioniated on seals yet so im all ears
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
