converting to dually
Postby 91bluecummins » Fri Oct 28, 2011 11:33 am
i just got a 1990 w250 and it does not have a bed im gonna put a flat bed on it and i want to convert it to a dually i dont want to change rear end from a dana 70 to 80 can u run just regular dually wheels without using spacers and if i haft to use spacers what size do i use ive seen on the computer some people use 4 inch
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Re: converting to dually
Postby dazedandconfused » Fri Oct 28, 2011 11:41 am
It's cheaper and safer to find a cab and chasis rearend in my opinion.
Postby 1STGENFARMBOY » Fri Oct 28, 2011 11:49 am
Not so much cheaper, but safer and easier yes.
you don't need a D80, just a Dually D70 1st gen rearend.
but if you could find a D80 that would be nice
Last edited by 1STGENFARMBOY on Wed Nov 30, 2011 12:26 pm, edited 1 time in total.
Postby collegekid » Fri Oct 28, 2011 3:11 pm
I've got a set of 4" spacers on mine to give me the dually rear end.....if I were to do it all over again, id just find a new rear axle and front hubs, it will be a lot cheaper in the end than putting spacers on the rear and on the front
collegekid
Postby dazedandconfused » Fri Oct 28, 2011 3:53 pm
Well I have access to a couple cheap c&c rears that's why I said cheaper. Can get a complete rear for $400 and that's what most want for adapters.
Postby collegekid » Fri Oct 28, 2011 4:18 pm
agreed, don't go adaptors if you're planning on putting the dually wheels on the front and rear.....in the end it'll cost more....throw a new axle under the rear and call it a day
collegekid
