D60 front Outer tube axle seals
Postby ahale2772 » Wed Nov 09, 2011 6:30 am
anyone ever tried/seen these?
http://mad4wd.com/index.php?main_page=p ... cts_id=162
seems like a good idea, ive got to pull my front carrier sometime before winter andchange my inner axle seals, but im sick of getting dirt in the axle tubes, or dirt on the splines when re-installing the shafts
im thinking even a homemade aluminum bushing pressed in might do the trick? just to keep the major stuff out
the axle should stay centered in the tube correct? even when in 4wd and turning?
Re: D60 front Outer tube axle seals
Postby BILTIT » Wed Nov 09, 2011 9:05 am
I know they are used alot in the chevy offroad world, seem to work well from what i recall.
Derek B.
BILTIT
