Rear Speaker Mount
Rear Speaker Mount
Postby RSWORDS » Sun Dec 04, 2011 3:30 pm
The rear speakers in the 92 are shot, they are replacement 4x10's but the are epoxied in place. Looks like there should be a bracket or something. Can someone tell me (or preferably show me a picture) of how the speaker mounts, I'm pretty sure I'm missing some parts.
RSWORDS
Re: Rear Speaker Mount
Postby Philip » Sun Dec 04, 2011 6:19 pm
The factory speakers are oblong. They mount with two screws. One in each end. The bolts go into plastic stand offs. My spare speaker boxes aren't here at the house. It will be a couple of days before I can get pic's.
Postby oldestof11 » Sun Dec 04, 2011 8:24 pm
A few well place holes will allow 6x9's back there. Easier to find and really great sounds. ;)
Postby RSWORDS » Sun Dec 04, 2011 8:50 pm
Philip wrote:The factory speakers are oblong. They mount with two screws. One in each end. The bolts go into plastic stand offs. My spare speaker boxes aren't here at the house. It will be a couple of days before I can get pic's.
This is the problem then, All aftermarket speakers have 4 holes, one at each corner...
How are people mounting aftermarket 4x10's?
RSWORDS
Postby PToombs » Mon Dec 05, 2011 6:09 pm
I have factory brackets on mine. They are a flat plate that screws in just below the double thickness in the cab corner. 1 screw goes in near the door latch, and the other is in the top edge. Or maybe it slides in a slot? I can't remember now. I'd take a pic for ya but I know I won't remember to do it. :oops:
Postby oldestof11 » Mon Dec 05, 2011 6:37 pm
The bottom of the plate pivots on the bottom screw near the door latch. The other has 2 tabs that go into the sheet metal on the sides of the top screw.
Postby PToombs » Mon Dec 05, 2011 6:45 pm
Yeah, that's it! Why the heck didn't you answer before I had to type all that? :roll:
Postby oldestof11 » Mon Dec 05, 2011 7:26 pm
Because that is not what he wanted to know. Not what it is mounted to, but how to mount a 4 hole speaker to the plate. ;) Reading comprehension old Padewan.
Postby PToombs » Tue Dec 06, 2011 6:59 pm
This is the factory bracket. The round spots are studs that mount the speakers. If you have these you can just drill a few holes and mount your new speakers. Sorry about the pic, I just shoved the camera in and let fly, the plate is verticle in the corner. :D
Postby Gots_a_sol » Wed Dec 07, 2011 10:11 am
this is how they look in the truck Image
I made an adapter to screw into the original holes and put a standard 4" round speaker in mine.
-Joe
Gots_a_sol
Postby PToombs » Wed Dec 07, 2011 6:23 pm
Those are the fancy ones for the ex cab trucks. Philips are like that. I got mine from a reg cab in the junkyard. I was going to take a better pic in the daylight from farther back but I forgot. :oops: I also forgot that the ex cab ones were that big.
