9/16 stud conversion?
Postby 93DodgeCummins » Wed Dec 07, 2011 8:09 am
Is there any good write ups of anyone doing any 9/16 stud conversions on our first gens?
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Re: 9/16 stud conversion?
Postby CumminsPower59 » Wed Dec 07, 2011 9:08 am
I converted my 92 to 9/16" studs, was really easy once I found enough studs and nuts. Easy as in pulling the rotors and drums off and pounding out the old studs and pressing new ones in. They can be driven in with a BFH, but since I have a press, I did it that way. I used some Dorman studs and nuts from various parts stores to get a total of 32, all I did was take in a 1/2" stud and we matched the end of the stud that sits in the hub up with something that would work using a dial caliper. In hindsight, I should have taken the time to find longer 9/16" studs as the ones I have now are a little too short in my taste to mount aluminum wheels on, but they work just fine for steelies. I believe I used studs that are for a Chevy K30. Hope this helps ;)
Postby 93DodgeCummins » Wed Dec 07, 2011 9:28 am
Did u have to drill out where the original studs were to the larger size?
93DodgeCummins
Postby Tacoclaw » Wed Dec 07, 2011 9:58 am
CumminsPower59 wrote:Easy as in pulling the rotors and drums off and pounding out the old studs and pressing new ones in. They can be driven in with a BFH, but since I have a press, I did it that way.
No, apparently the studs he found had the same press-in diameter as his 1/2" studs.
Postby CumminsPower59 » Wed Dec 07, 2011 10:09 am
No drilling, just pound/press the new ones in and your golden! :D
Postby ahale2772 » Wed Dec 07, 2011 10:09 am
the shank is 5/8 i believe, so both 9/16 and 1/2 step down
Postby 93DodgeCummins » Wed Dec 07, 2011 10:15 am
9/16 is the stud size for an 2006 dodge isn't it? I got a set of 06 dodge rims i want to put on.
93DodgeCummins
Postby CumminsPower59 » Wed Dec 07, 2011 6:56 pm
The diameter of the stud has little effect as to which wheels are put on, as long as there is ample length and the face of the lug nut fully captures and centers the wheel. As for running aluminums, make sure that there is plenty of length, I know the stock 1/2" studs can be too short for some aluminum wheels as older wheels have a thicker center. Newer ones aren't as thick. The 9/16" studs are a good upgrade, mainly piece of mind IMO. If you go with the 9/16" studs, try to find the longest ones you can, so that there won't be an issue running the newer wheels...and you will more than likely need spacers to run them, otherwise, the wheels are stuffed clear in and it looks goofy as all get out :lol:
Postby Tacoclaw » Wed Dec 07, 2011 7:00 pm
Yeah, I think you can just use the later model lugnuts for those wheels, can't you?
Postby CumminsPower59 » Wed Dec 07, 2011 7:09 pm
I wouldn't be suprised if they are the same, check to be sure first, as I bought new studs and lug nuts when I converted my 92, I had a set of 00-02 aluminums I got for $free.99, with lug nuts, come to find out I didn't need to buy the new lug nuts, as the ones I had would work... :roll:
Postby 93DodgeCummins » Wed Dec 07, 2011 9:00 pm
the 06 rims i got came with bigger lug nuts than what is originally on my truck
93DodgeCummins
Postby CumminsPower59 » Wed Dec 07, 2011 9:57 pm
Yup, apoligies for not sorting out that last mess, I was under a Yukon when I typed it :roll: Yes, the lug nuts that you have with the '06 wheels might work when you upgrade to the 9/16" studs, I'd still check to be certain. If they are proper, then that saves some $$$, IIRC, the lug nuts I decided on were about $2 a piece. I know I spent around $200 for everything, and that included new wheel seals and a few cans of brake cleaner ;)
Postby 93DodgeCummins » Thu Dec 08, 2011 6:38 am
For my newer rims i have to run a wheel spacer so i was thinking they shouldn't stick out any longer 1.5 inches because thats the thickness of the spacer? So would i be best off taking some studs out and go to the parts store to find what i want?
93DodgeCummins
Postby ahale2772 » Thu Dec 08, 2011 7:06 am
FYI, if you want to keep all the lug nuts the same as the rear, a Chevy 1 ton stud from a '91 K series (4wd) will fit in the Dodge hub.
It uses the same shank with the smaller thread diameter (9/16" instead of 5/8").
quote from Mr. Nixon himself
edit... to clarify, this is when i went from d70 to d80 in the rear, so my lugs in the back are 9/16 and fronts are still half
Postby CumminsPower59 » Thu Dec 08, 2011 8:13 am
IIRC, I ended up using the same studs as a Chevy K30/V30. Since there is little difference in the Chevy Dana 60 to Dodge Dana 60, the studs from the K30 should work. As long as the shank size is appropriate, you can run any diameter of stud ;)
