front end add a leaf problem
Postby cumminsbo87 » Sun Dec 18, 2011 7:31 pm
I have 2 inch add a leafs to install front and back on my truck. However I have a problem with the front. There is 1 u-bolt and and another threaded rod that goes into the axle to secure the leaves on the passenger side (pumpkin side). there is not enough room for another leaf without either getting a longer threaded rod, or do i use a bolt to replace it or what? im lost its a 4500lb axle
'92 w250 reg cab 4x4, 5spd 188k, denny t stage 2, fuel screw, smoke screw, afc tweaked, 6 inch stack 3.55's
cumminsbo87
Re: front end add a leaf problem
Postby BILTIT » Sun Dec 18, 2011 8:14 pm
Use longer bolts. Why are you adding a leaf? Looking to get more height for bigger tires or the old leaves wore out?
I would recommend these instead of add-a-leaves:
http://diy4x.com/cart/index.php?route=p ... uct_id=128
Derek B.
BILTIT
Postby BobS » Mon Dec 19, 2011 4:53 am
Longer grade 8 bolts are available from www.mcmaster.com or your local truck spring shop. I believe they are 9/16" fine thread but confirm before ordering.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby ahale2772 » Mon Dec 19, 2011 5:29 am
i believe they are 9/16 fine as well, If you can, try to get a stud. Stripping the threads in the axle housing due to insufficient bolt length would blow big-time
Postby BobS » Mon Dec 19, 2011 6:32 am
I tried to find a 9/16" fine thread stud when I did the same basic thing. All the commercially produced grade 5 and higher studs were not available in 9/16". They skip from 1/2" right into 5/8". The other option might be finding a fully threaded grade 5 rod.
BobS
89 D350 Stock
BobS
Postby BILTIT » Mon Dec 19, 2011 3:06 pm
Just use a bolt, its been done a thousand times over the years by many a thousand people. I have done it twice on two different trucks without issues, just be sure to get the right length bolt.
Derek B.
BILTIT
Postby 142autox » Mon Dec 19, 2011 5:18 pm
BILTIT wrote:Use longer bolts. Why are you adding a leaf? Looking to get more height for bigger tires or the old leaves wore out?
Any reason for not doing add a leafs? I know that they too will sag over time.
I have some F350 overload leafs that I removed when I installed lifts that are sitting there waiting to go under my front end. I'm about 1/2" off the bump stops now and I figure anything would help.
93 W350 dually, A518. DDP stage 1 injectors, and typical pump adjustments.
142autox
Postby BILTIT » Mon Dec 19, 2011 6:47 pm
Main reason i wouldn't use them is that they usually stiffen up the suspension, not needed on these old bricks.
Derek B.
BILTIT
Postby cumminsbo87 » Thu Dec 22, 2011 11:47 am
Yea i just wanted a few more inches, and put a little wider black wheels for a better stance is all. The truck already rides like a tank, but its not my daily driver, so paying all that $$ for soft ride lift springs aint in my budget.
cumminsbo87
Postby 142autox » Thu Dec 22, 2011 6:04 pm
Long leafs seem to not adversely affect ride quality as much as short leafs. I know, seems counter intuitive but that's my experience.
142autox
Postby m880cummins » Fri Jan 06, 2012 8:25 pm
DO NOT USE ADD A LEAFS!!! I would never do it! My donor truck had them and the add a leafs wear through the top leaf over time causing fatigue. This happens mainly on the front of the spring by the front spring eye. Mine had 190,000 on it (not sure about add a leafs) but the spring was rubbing on the add a leaf edge and the spring had a 15* bend and the contact point and was half as thick. The sharp spring edge on the add a leaf is almost like a file to the top leaf. Every bump takes a little bit off.
SUNY Maritime Class of 2017!
m880cummins
Postby 142autox » Sun Jan 08, 2012 7:34 pm
Now that's a sound reason for me to NOT put the add a leafs in. Thanks for the heads up.
142autox
Postby cumminsbo87 » Sun Jan 08, 2012 7:50 pm
well what about using 2 inch lift shackles on the back and, having the front springs re-arched? Do you think they can get 2 inches out of the old ones on the front?
cumminsbo87
Postby BILTIT » Sun Jan 08, 2012 8:10 pm
Derek B.
BILTIT
Postby cumminsbo87 » Tue Jan 17, 2012 6:51 pm
sweet! I never would have found that otherwise, thanks!
cumminsbo87
