PToombs wrote:There is a number problem in a lot of the parts places. It lists the right bearing, but it's the smaller one. Caleb is correct, you need to make sure you get the 1.57" ID bearing not the 1.37 one.
I got the correct one the last time I changed mine in the fall of '10. Carquest number B-HB99107A. I googled it and got 2 hits off chevy forums about the wrong size. There is another number they used, HB88508A for the 1.57 bearing.
I added this info and numbers to help anybody in the future, if the search works.
