Looking for dually light mounting information
Postby Bschwarzli » Sat Jan 28, 2012 8:54 am
So, I have this wonderful idea of adding the 5 rear clearance lights to the truck as it never had any. Question is where do I put the holes!? I have no 350 friends locally to measure off of. Are they on the tailgate, the box?? Also how far apart and how are they centered?
Next question is how are they mounted? Screws? Bolts?
Thanks,
Robert
1993 W350 Dually Crew Cab - 1997 12V, NV5600, NP205, Dana 60 F, Dana 80 R, Gear Vendors, PDR Twins, 4 link rear, so mostly stock really :)
1990 W250, NV5600, 3.07s, Gear Vendors, Super HX40, kinda stock :D
Bschwarzli
Re: Looking for dually light mounting information
Postby RumbleFish » Sat Jan 28, 2012 9:30 am
They are mounted to the tailgate. standing back, they should be in line with the fender lights. The harness goes thru the left side tailgate hinge.
Postby Bschwarzli » Sat Jan 28, 2012 6:26 pm
OK. That makes sense. As for distance apart?
Bschwarzli
Postby PToombs » Sun Jan 29, 2012 1:44 pm
Some guys put them under the gate on the bed for more protection and they don't have to be unplugged to remove the gate. Depends on how original you want it to look. ;)
Postby RumbleFish » Sun Jan 29, 2012 3:50 pm
I did that on my srw w350. I liked it. But the tailgate lights all lined up with the fender lights look pretty cool. Ill have to look, but last I knew I had a tailgate harness. Wouldn't be hard to duplicate it with readily available connectors.
Postby Bschwarzli » Fri Feb 03, 2012 10:42 am
Pete
For the crew this thing needs to look factory so..... :D
(well, semi facotry with stacks, west coast mirrors, 19.5......you get the idea! :D)
Bschwarzli
Postby PToombs » Fri Feb 03, 2012 6:12 pm
Yup, Bob's factory! :jumpsmile:
Postby Bschwarzli » Fri Feb 03, 2012 7:14 pm
It will be provided you dont look under the hood, under the body, or inside. :D
Bschwarzli
