I need help ASAP
I need help ASAP
Postby oldestof11 » Sat Jan 28, 2012 2:17 pm
I am in the process of changing the POS Dodge slip joint for a U-joint. The (#&%@& roll pin had me cut through the top of the joint to be able to drive it out. A few times over 12 hours I hit it with PB Blaster. Drove to my parents place as they have more tools. Hit it with heat and pb blaster and the %^#* pin wouldn't come out. I have spent 5 hours trying to get it out before cutting a slit right above it and driving a screwdriver into the to spread out enough from me to drive it out. Still gave me trouble but it is out now. Note, I was driving on the side with a slightly smaller hole hitting it towards the larger one. Now the :yuck: :/ :evil: joint wont slide off the splines. Pull the dust boot for the joint and it was beat to heel from one of the PO of my truck.
Am I screwed or do I just need to work the POS off with something other than a prybar??? ANY help is appreciated. I am thinking of just leaving it till it is 40* tomorrow...
Re: I need help ASAP
Postby bgilbert » Sat Jan 28, 2012 3:01 pm
Lots of pry bar and hammer. Generally the input seal on the steering box will leak (more) after this job. :roll:
Bill Gilbert
bgilbert
Postby oldestof11 » Sat Jan 28, 2012 3:10 pm
Like how much hammer? I am using a 2lb right now...
Would a ball joint separator work?
Postby RumbleFish » Sat Jan 28, 2012 3:52 pm
Yes it will, as long as the fork isn't too wide.
Postby Mark Nixon » Sat Jan 28, 2012 5:52 pm
Or a tie rod separator. :D
DON'T HEAT IT! :shock:
Postby oldestof11 » Sat Jan 28, 2012 7:10 pm
I brought the heat up to a warmish feeling on my bare hand with a small propane torch as it was 30* out. What would happened if heated too much? I had the truck running and I turned the shaft to try and get a nice even warm up.
Postby Mark Nixon » Sat Jan 28, 2012 7:28 pm
Heating it too much may take out the seal.
If you could touch it, you probably didn't hurt it with the heat.
Postby oldestof11 » Sun Jan 29, 2012 2:14 pm
Ball joint separator did the trick. 10 minutes later it was off. Now I know why it was loose. The spring was missing and the 1 piece of metal wore into the shaft about 1/8"!!! :shock:
Working nice now! Best $50 yet.
Postby RumbleFish » Sun Jan 29, 2012 3:56 pm
$50?? Pshh. I scored a nearly new borgeson shaft from the upull for $9
Postby oldestof11 » Sun Jan 29, 2012 4:41 pm
If I would have known that, I would have bought it from you for $60...
Postby RumbleFish » Sun Jan 29, 2012 5:45 pm
lol. i put it on my rc. it used both lanes going down the road!
