removing leaf springs
Postby fatstack » Sun Mar 11, 2012 7:03 pm
Will I be able to tow if I remove all but two rear leaf springs? All I tow is a 20 ft gooseneck. Thanks
89 d250 getrag ripper, pump maxed,timed to the head,pull cable shutoff, 354 spring, straight pipe, 4:10 gears, in the shop: he351cw and 3:07 gears
90 w350 nv4500,ic motor, stock, 5" stack w a western hauler on back
fatstack
Re: removing leaf springs
Postby BILTIT » Sun Mar 11, 2012 8:27 pm
I doubt it.
Derek B.
BILTIT
Postby fatstack » Sun Mar 11, 2012 8:58 pm
Dam the bad luck. How can I get traction on pavement and still tow? Also my new diff has a lincoln locker
fatstack
Postby JustinRhodes » Sun Mar 11, 2012 9:44 pm
Maybe the 2 leafs + air bags for towing would work. Idk just an idea
JustinRhodes
Postby fatstack » Mon Mar 12, 2012 10:02 pm
Thats kind of along the lines of what I was thinking, or traction bars would be all i could daily drive along with all the leaves? Could I see some homebrew pics of either or?
fatstack
Postby Tacoclaw » Mon Mar 12, 2012 11:52 pm
If you're pulling a trailer, I would think a welded diff will be way more of a concern than your truck sitting on it's bumpstops all the time.
What sort of traction are you trying to achieve? Are you wanting to stop wheelhop or what?
WHen your truck isn't hooked to a trailer, what are you planning to do with it?
Postby fatstack » Wed Mar 14, 2012 11:09 pm
Just trying to achieve maximum traction on pavement in the 1320. Its generally a hot rod playtoy when not hooked to a trailer. Thanks
fatstack
