tie rod end adjusting sleeve
Postby jacobwebb57 » Tue Sep 04, 2012 5:51 pm
anyone know where i can find one of these i was gonna make one but i need the taps..anyone done this or know where i can find a new one
91.5 4x4 5 speed, dennyt stage 2. ddp 50 horse injectors. glow shift boost, fuel pressure, egt, autometer tach, 60lb vavle spring, 3800 gov springs, 1 ton axles, custom intake, 4'' exaust, hx35w pump turned up 3 turns raptor pump, and 1/8 timing.. new injectors sooner or later
jacobwebb57
Re: tie rod end adjusting sleeve
Postby BILTIT » Tue Sep 04, 2012 9:01 pm
Derek B.
BILTIT
Postby Fred_M1010 » Mon Sep 17, 2012 2:17 am
Don't they make these sleeves any more?
You could let a company like WFO or ORD make you a complete new tie-rod.
It would be cheaper than buying the taps at least.
-91.5 W250
Fred_M1010
Postby earthdad » Mon Sep 17, 2012 8:37 pm
I bought DOM tube 5' , threaded sleeve adapters and jam nuts and it was less expensive than just a tap. All you need is to measure, measure, measure, cut and weld them on. I needed to put new rod ends on and they were literally fused into the tube. I dont think my Dana 60 had adjusting sleeves though. It is just a split end tube with a clamp. Im assuming you got a 60 in front and not a 44.
http://www.ballisticfabrication.com/Ste ... _c_13.html
earthdad
Users browsing this forum: No registered users and 75 guests
