Dana 70 speedy sleeve? Leaking seal again...
Re: Dana 70 speedy sleeve? Leaking seal again...
Postby CumminsPower59 » Fri Feb 07, 2014 11:03 am
I don't mess with re use of the nylon lock nut, I swap it out with nuts that go on the front axle (D60). Works very well ;)
Postby 762frmafr » Tue May 26, 2015 12:14 pm
Does anyone have the Part numbers for the Speedi Seal and 2 piece seal for the Dually spindles? After researching the part numbers in this post, I don't believe they will work. The part number I get from the parts store for my wheel seal is 455086 National Oil Seal.
762frmafr
Postby little doug » Sun Jun 21, 2015 5:07 pm
You are right . I have learned the seal and wear sleave #s I posted are wrong ...too small .
The sleeve should be somewhere in the range on page 7 of this link. I haven't looked in depth yet... If you google the part # starting 99*** SKF you can get price and dimentions from Amazon.
http://www.skf.com/group/products/seals ... index.html
93 W250 LE extra cab, 5 speed,warn winch, tach,piro,boost gauges. Gov.spring and fuel pin... Play truck
-91 W350 LE reg cab chassis.exxxxtended 175"wb, banks intercooler,on board air ,5 speed,... Work truck
little doug
Postby Moebiusgold » Tue Dec 13, 2016 7:43 pm
The DRW repair sleeve is SKF 99287. Can't seem to come up with the trick axle seal number though
92 W350 DRW
Moebiusgold
Postby little doug » Wed Oct 31, 2018 1:33 pm
So after a couple of years, I finally got my leaky rear axle seals fixed. So the #99287 wear sleeve worked on my 93 w250 but did NOT work on my 91 w350 Cab & Chasis dually. The W350 had a 3" dia spindle where the seal rides, not 2 -7/8" like the w250. For my w350 I used #99303 wear sleeve and 455086 oil seal. The parts guy said my dually axle was a 9000 lb rated axle.
little doug
