Cab Mounts?
Cab Mounts?
Postby off_kilter » Thu Jan 10, 2013 8:25 pm
So the truck i'm picking up needs new rear cab mounts. Anyone have a source for these my google fu has turned up nothing so far :(
Thanks in advance!
EDIT: SO just saw the body section...the cab mounts bolt to the chassis so its still kinda relevant :/
off_kilter
Re: Cab Mounts?
Postby Mark Nixon » Thu Jan 10, 2013 11:12 pm
Which cab mounts?
Body side or frame side?
Re: Cab Mounts?
Postby off_kilter » Sat Jan 12, 2013 5:24 pm
Body side
thanks in advance
off_kilter
Re: Cab Mounts?
Postby krazykiller » Tue Jan 22, 2013 4:09 am
about 3/4 away down the page you will see the body mounts from what i remeber these will work with alittle work for trucks all the way up to 1993.
http://www.jimsautoparts.com/mopar_perf ... .htm#doors
krazykiller
Re: Cab Mounts?
Postby Xjeepyjx » Sat Jan 26, 2013 1:08 pm
-Sam
early 91 8W350 cab/chassis converted to pickup
Mechanical difficulty… can always be whipped.
-Clessie Cummins
Xjeepyjx
