PToombs wrote:Ellis, mine have been in for 3 years or so and it still sits up there pretty good. It's buried in the barn so I can't measure it right now. If I ahd to guess I'd say it has 3-4 inches between fender and tire. It's settled about an inch since I put them in.
Andy, 1 fits and the other doesn't.
dazedandconfused wrote:Yeah thats no help Pete.i was wondering how much they changed.
ellis93 wrote:5716s:bar diameter .937 install height 12.75 load 3251
Mark Nixon wrote:ellis93 wrote:5716s:bar diameter .937 install height 12.75 load 3251
I have a set of those that I bought from Rock Auto, lying here on the floor, new in the box.
Are you sure you wish to use GM spec parts in your Dodge?![]()
I actually bought mine for the carhauler and have yet to use them.
dazedandconfused wrote:PToombs wrote:Ellis, mine have been in for 3 years or so and it still sits up there pretty good. It's buried in the barn so I can't measure it right now. If I ahd to guess I'd say it has 3-4 inches between fender and tire. It's settled about an inch since I put them in.
Remps wrote:Iirc, the 93 I used to own was 34“ from ground to wheel well lip sitting on 265/75/16 tires and 5716 springs. just for laughs, i bolted a 315/75/16 on the front to see if it would even go on. It had about 1/2“ clearance at the tightest spot, wouldnt have been able to turn the wheel much. The ride was firm, not as firm as the W250 though.
ellis93 wrote:Remps wrote:Iirc, the 93 I used to own was 34“ from ground to wheel well lip sitting on 265/75/16 tires and 5716 springs. just for laughs, i bolted a 315/75/16 on the front to see if it would even go on. It had about 1/2“ clearance at the tightest spot, wouldnt have been able to turn the wheel much. The ride was firm, not as firm as the W250 though.
So those will work huh? Cool
