6" Lift
6" Lift
Postby walkerkd » Fri Feb 15, 2013 5:46 pm
My new to me beater. Image
Shes Named Rust Bucket! haa haa.. but i dont even care runs perfect and turn the key and never hear the starter she bust right off!! anyway talk to bill today at alcan springs ordered my 6" lift cant wait 3 weeks willl take forever. Let me tell you they are by far the most pleasant people to talk to! customer service is awesome!
walkerkd
Re: 6" Lift
Postby dazedandconfused » Fri Feb 15, 2013 5:54 pm
Nice truck
Re: 6" Lift
Postby walkerkd » Fri Feb 15, 2013 6:03 pm
shes rusty as heck but i like her. haa haa.. No running Boards anymore.
walkerkd
Re: 6" Lift
Postby walkerkd » Fri Feb 15, 2013 7:09 pm
hey guys i ordered the kit but i may have made a mistake it looks like the 6" lift requres quit a bit of stuff to replace. brake lines, pitman arm, steering spacer. and drive shafts. i read somewhere that it was not requred then starting reading again and it seems it is. can anyone tell me for sure. i will call Bill tomorrow or monday morning and have him build me a 4" kit seems more safe i wanna run 37x12.5x16.5s but i dont have the budget to do a complete build up right now.
walkerkd
Re: 6" Lift
Postby RumbleFish » Fri Feb 15, 2013 7:17 pm
I put a 5.5" Superlift on my ramcharger, and had to do a front brake line, steering block, and a front drive shaft spacer. I also did an adjustable draglink, but it may not have been mandatory.
Re: 6" Lift
Postby walkerkd » Sat Feb 16, 2013 4:01 pm
so prob better and safer idea would go 4 inch... dang i should have done a bit more research i will get the skyjacker drop pitman arm and adjustable draglink my main concern was not messing with drive lines and stuff.
walkerkd
Re: 6" Lift
Postby RCCUMMINS89 » Sat Feb 16, 2013 5:43 pm
Front drive line will need to be lengthened, will on 4 as well.
I'm not sure on rear driveline, because the extended cabs are the 2 piece, correct? The std. cabs don't need lengthened.
I've never had to lengthen a brake line with a 6" susp. lift.
You will need the Steering block, OR a diff. pitman arm.
That's all
Re: 6" Lift
Postby walkerkd » Sat Feb 16, 2013 6:56 pm
well in that case hell do the 6" drop pitman and no matter what i will have to do the drive line so y not do full 6" plus with the 37s i wanna run it should look even better.
walkerkd
Re: 6" Lift
Postby Ram360man » Mon Feb 18, 2013 10:09 am
4 inch lift on mine. Did a 4 inch drop pitman arm and ground on the cv yokes. where hitting when it was flexed out. Thats all i did. Id run the 6 inch regardless with 37s. I can make 33s hit if I push it hard enough. That truck doesn't look like a rust bucket either really. lol
1989 W250. Maxed fuel pump. 5x14. 63/68/14. PS Intercooler. 4200 gov spring. 188/220 cam. Built 727
1989 W250 60mm gds. 2.5 inch crossover. turned up pump. Stock 727.
Ram360man
Re: 6" Lift
Postby walkerkd » Mon Mar 11, 2013 6:23 pm
Well Let me tell you guys Bill Ford at Alcan Springs is a great guy to work with and my springs came today and man they look awesome. I mean AWESOME. pics to come in Near future. oh i got the 6".... and i got a M&H M3 in the mail too! hahaha...
walkerkd
Help
Postby walkerkd » Tue Mar 12, 2013 4:11 pm
I was trying to order my ubolts and for the rear on rock auto i got it figured out as 9/16" X 2 9/16" X 16 3/4" but the fronts they are all the same but differnt widths. does anyone know what i need for the w350 heres what they got.
9/16" X 4 1/16" x 8 1/2" Round Bend; Front Spring; Passenger Side Outboard
9/16" X 3 5/8" X 7 5/8" Round Bend; Front Spring; Passenger Side Outboard
9/16" X 3 1/4" X 8 1/2" Round Bend; Front Spring; Drivers Side
and i will get the bolt to replace the stud if it comes out when uninstalling.
walkerkd
Re: 6" Lift
Postby walkerkd » Wed Mar 20, 2013 7:12 pm
heres the before and after and whats to come..
Before
after Lift
Future
walkerkd
Re: 6" Lift
Postby RCCUMMINS89 » Wed Mar 20, 2013 7:22 pm
I'd swap a 3" block in the rear to replace your 6".... make it ride a little bit more level. Up to you though.
Re: 6" Lift
Postby walkerkd » Wed Mar 20, 2013 7:23 pm
cool good idea!! do u cut the 6? or buy a 3"
walkerkd
Re: 6" Lift
Postby RCCUMMINS89 » Wed Mar 20, 2013 7:32 pm
Could probably swap someone with a non i/c truck..... The i/c trucks got a 6 from the factory for increased payload, where as the non i/c trucks got a 3
Or buy the 3, should run about 50
