Tire Size Advice - 285/75/16 vs 265/75/16
Postby nitrofumes » Wed Mar 06, 2013 6:07 am
Hello everyone!
I purchased a very clean '92 CC 4x4 D250 this weekend and I am beginning to do some maintenance and repairs – starting with new tires as the old one are dry rotted a bit.
I saw a picture of CumminsPower59's truck with the stock steel wheels and 285/75/16 tires and I really loved the look. Searching thru the forums some more I see that many people have mixed feelings about this size – most seem to say or think it is too big for the stock 6” rim. I will be towing 5-6k lbs a couple times a month and I am curious as to how they tow as well.
I realize I could go with 265/75/16 and be safe and that is what I may end up doing since my truck has a pretty high gear as is and the 285/75/16's will only add to this.
Any advise or opinions on this?
Thanks in advance!
nitrofumes
Re: Tire Size Advice - 285/75/16 vs 265/75/16
Postby CumminsPower59 » Wed Mar 06, 2013 6:44 am
Howdy!
You shouldn't have an issue running 285's on stock steel wheels, as I ran them for 30k on my 92 without a single issue. I did tow a few moderatley heavy loads with it, and the D rated 285's held up quite well. Some people don't like they way they look or whatever, but I went the 285's on the stock wheel route because I had the tires, but didn't want to buy another set of wheels.
Hope this helps ya!
Postby nitrofumes » Wed Mar 06, 2013 7:23 am
Thanks for the reply! Your truck looks awesome btw!
I personally like the way they look and I'm not about to buy another set of wheels at this point - I have other priorities on the truck.
That does help me a lot - Thank you very much!
nitrofumes
Postby Hansen01 » Wed Mar 06, 2013 9:20 am
285's might rub on your drag link if you turn all the way to the right, but not a huge deal
Under construction...
Hansen01
Postby CumminsPower59 » Wed Mar 06, 2013 1:26 pm
Hansen01 wrote:285's might rub on your drag link if you turn all the way to the right, but not a huge deal
I forgot all about that, as the tires I had did ever so slightly.
nitrofumes wrote:Thanks for the reply! Your truck looks awesome btw!
You're welcome. I have since sold the truck, and bought another ;)
Postby nitrofumes » Thu Mar 07, 2013 5:34 am
I figured that they'd rub - as long as it's nothing severe it's a non issue I think. I think I'm more worried about what it'll do to the overall gearing of the truck than anything at this point. That reminds me I need to figure out exactly what gear I do have...
CumminsPower59 wrote: You're welcome. I have since sold the truck, and bought another ;)
Well I guess I can post pictures of my truck without fear of copying you - my truck is the identical twin of your old one haha.
nitrofumes
Postby CumminsPower59 » Fri Mar 08, 2013 9:12 am
nitrofumes wrote:I figured that they'd rub - as long as it's nothing severe it's a non issue I think. I think I'm more worried about what it'll do to the overall gearing of the truck than anything at this point. That reminds me I need to figure out exactly what gear I do have...
My 92 had 3.54's in it and didn't have any issue with running 285's...
Post away! :mrgreen:
Postby RumbleFish » Fri Mar 08, 2013 11:56 am
I stumbled across a good deal on some 255/85-16s. Just over 33" tall, and narrow enough it clears everything. I like them so far.
Postby CumminsPower59 » Fri Mar 08, 2013 12:48 pm
RumbleFish wrote:255/85-16s. Just over 33" tall, and narrow enough it clears everything.
I thought about going with some pizza cutters for my 91...
Postby TRACTJDS0428 » Sun Apr 14, 2013 7:17 pm
Been running 285/75-16 on my '93 W250 for several years now and never had a problem aside from finding tires that hold up under the Cummins. BFG's lasted ok, Daytons didn't last at all, getting ready to throw some Toyo Open Country's on it.
1993 Dodge W250, Cold Air, Borg Warner 60/68 turbo. 4" down pipe. 5x14 Injectors. Pump Mods. Airdogg II 165, Billet Fuel Tank Sump. ATS valve body, ATS converter, Pyro, Fuel pressure, Boost and Trany temp gauges. 72" T-Rex Products Long Bars. 285/75-16 Toyo Open Country M/T's. Western 9Ft MVP Ultra Mount V-Plow.
TRACTJDS0428
