W350 Carrier Bearing
Postby matthewh » Fri May 10, 2013 5:09 pm
Anybody know if the 2wd trucks and the 4wd trucks use the same carrier bearing, the 1.57 id one, Carquest number B-HB99107A? Mines on its way out, and Carquest lists several options. I wasn't able to find a 4wd part number on here, just the above mentioned one from Caleb's post.
Thanks
matthewh
Re: W350 Carrier Bearing
Postby u2slow » Sun May 19, 2013 12:33 am
My '93 W250 used the 1.5xx" one. I ordered the smaller one first... luckily a friend could use it on their Chevy S10 pickup lol!
93 W250 Club 6BTA/5spd/3.54/Dana80/~3"lift/2gen leafs/3gen wheels/HX35/5x.012s
90 D250 6BT/5spd/3.54PwrLok
84 Ramcharger [Project} D250 6BT/5spd/3.07
... various other 75-05 mopar truck products
u2slow
Postby bgilbert » Sun May 19, 2013 5:16 am
Same one 2wd or 4wd. Spicer part number is 210866-1X. http://www.drivetrainamerica.com/p-4989 ... aring.aspx
Another one that works for our trucks is Spicer 210140-1X. I've used it in my crew cab. It shares the same bearing ID as the 210866-1x, but has more rubber I believe.
Bill Gilbert
bgilbert
