Air bags
Re: Air bags
Postby fxr3 » Fri Dec 20, 2013 7:57 pm
Kool. I've learned what axle wrap is and what traction bars are too! I even kinda understand what you've done to your rear suspension! Thats too radical for me, but I admire your willingness to change that suspension! I'm going to talk to spring guy after holidays, see what he thinks…..
I probably should just not ride around in any late model diesel 4x4's anymore….. that is where my problems started!
My loaded fuel tank was working fine until an innocent ride in 09 chevy 3/4 diesel… rode like 1/2 ton, sounded like gas…..
fxr3
Re: Air bags
Postby DMan1198 » Tue Dec 24, 2013 12:04 pm
My 12 3500 has only a slightly softer ride than my 93 which I thought was weird, but whatever. Maybe it's the bench seat being so soft it makes up for harder suspension
Re: Air bags
Postby brandonmgreer » Sat Apr 25, 2015 4:56 pm
Gots_a_sol where did you get those lower bag mounts, nd whats the diameter on those bags? My d250 rides like chit... It'll almost knock your teeth out.
I'd like to use the bags from a Peterbilt low air leaf, but they're way too tall, like 14". Im thinking a bag off of a Kenworth. Large diameter. Id like to bag the front as well, but i don't see a good way to do a lower mount without having the bag in a bind.
White/black 92 D250 manual conversion, Pump tweaking is about it right now...
95 CCLB 4X4 5 speed being but back together from a wreck
99 Kenworth W900 flat top, Tuned 500 Detroit, BW 75mm 1.32A/R, 5915 injectors, 13 speed, 3.55's
brandonmgreer
Re: Air bags
Postby Tacoclaw » Sat Apr 25, 2015 8:06 pm
There's some Kenworths that come in sometimes with really short airbags. I'll try to find out what it's called.
Re: Air bags
Postby brandonmgreer » Sat Apr 25, 2015 9:44 pm
My Kenworth has the AG200 suspension. Those are the triangulated 4 link bags... the shorter ones. I want to try the AG400 bags, I think. Its either theAG400, or the AG100. I'ts still an 8 bag setup, but taller bags and uses a big sway bar underneath.
brandonmgreer
Re: Air bags
Postby oldestof11 » Sun Apr 26, 2015 5:45 am
Look up Slam Specialties.
http://www.slamspecialties.com/compare.html
After talking with them, their RE7 and RE8's are a good replacement for our trucks. They are 200psi rated, the RE7's max height is close to our front coil springs, the rear with RE8s carry nearly 3k lbs a piece. MAny highly recommended reviews of people who switched from Firestone to the SS bags.
Re: Air bags
Postby brandonmgreer » Sun Apr 26, 2015 10:02 am
Thanks for the info Oldestof11. I will definately check those out, more in depth. One day, I might actually get around to getting this done... along with my power upgrades!
brandonmgreer
Re: Air bags
Postby Gots_a_sol » Mon Apr 27, 2015 4:34 pm
brandonmgreer wrote:Gots_a_sol where did you get those lower bag mounts, nd whats the diameter on those bags?
Bags are Slam Specialties SS-8's.
These are the axle brackets http://thorbros.com/bag-brackets/axle-b ... axle-lower
-Joe
Gots_a_sol
Re: Air bags
Postby brandonmgreer » Thu Apr 30, 2015 3:05 pm
I'll check it out! Thank you sir.
brandonmgreer
