Wanting to bypass RAWL
Postby 1992gen1_fan » Thu Sep 12, 2013 5:33 pm
Hello, I'm thinking about buying a short piece of brake line and bypassing the RWAL valve unit mounted on the frame above the rear axle. I'm sure I've read something about doing this but can't seem to find any info on it. Tired of bad brakes, I think the RWAL might be interfering with the rear brakes even though the wires are disconnected.
Has anyone here done this? Any tips? Looks like the in/out lines to the unit are different size. What adapters are needed?
Thanks in advance :D
1992gen1_fan
Re: Wanting to bypass RAWL
Postby ellis93 » Thu Sep 12, 2013 6:11 pm
Yes to all,I'll find the info for you. ;) http://www.1stgen.org/viewtopic.php?t=6199&highlight=
Postby 1992gen1_fan » Thu Sep 12, 2013 7:20 pm
Ok, thanks for the link. I should have searched "abs" instead of RWAL. Stopping by the parts store for some fittings tomorrow :D
1992gen1_fan
Postby CumminsPower59 » Thu Sep 12, 2013 8:19 pm
I didn't need any fittings, just hooked the RWAL inlet line to the rubber line going to the axle...no special fittings needed.
Postby 1992gen1_fan » Fri Sep 13, 2013 3:21 pm
^ I did'nt think of that. I bought 2 fittings at the local parts store today. I'll install them some time soon. Thanks for the replies.
1992gen1_fan
Postby ellis93 » Fri Sep 13, 2013 4:34 pm
CumminsPower59 wrote:I didn't need any fittings, just hooked the RWAL inlet line to the rubber line going to the axle...no special fittings needed.
Mine wouldn't do that,two very dissimilar fittings.
Postby 1992gen1_fan » Fri Sep 13, 2013 6:03 pm
I got the 2 lines put together a few minutes ago. The fittings listed in the link worked :D
^ X2 a thread adapter is needed. ;)
1992gen1_fan
Postby PToombs » Sat Sep 14, 2013 5:19 pm
If you replace the line from the front to rear it will screw right into the hose. The factory lines have weird fittings on them, replacement lines will hook right up to the hose.
Postby 1992gen1_fan » Sun Sep 15, 2013 10:54 am
I got the brakes bled, the rear wheels will skid on gravel if I stomp the brake pedal now. The pedal is still spongy as it was before though. I will bleed the brakes a couple more times this week, putting a few miles on it in between. I'm hoping there is just some air in there somwhere.
1992gen1_fan
