2nd gen springs?
2nd gen springs?
Postby 93 W350 LE » Fri Oct 04, 2013 7:52 am
Was working on a friends 01 2500 and noticed the rear spring pack only has 3 springs and a helper. Where my 93 350 has 6 springs in the pack. Can we use the newer springs? Or will they not work? Different length?
Thanks.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
Re: 2nd gen springs?
Postby DMan1198 » Fri Oct 04, 2013 5:17 pm
You'd have to take a tape measure to it. They have to be 2.5 inch wide. Otherwise they should work
Postby Black93 » Fri Oct 04, 2013 6:03 pm
Best I can remember the 2nd gens are 3" wide, I can't remember the length though.
Black93
Postby PToombs » Sun Oct 06, 2013 4:26 pm
2nd gen springs are 1/2" wider and longer, so they won't work without a major rework job. I was looking at that myself and just bought new ones.
Postby 93 W350 LE » Tue Oct 08, 2013 3:58 pm
Thanks. I knew it couldn't be so easy.
Eric
93 W350 LE
Postby rb70383 » Thu Oct 17, 2013 1:54 am
2nd gens have 2.5" and 3" wide springs. Depends on the gvw. Over 8800 is the 3". Length is 63" iirc.
Here it is:
http://www.generalspringkc.com/Leaf_Spr ... s/1916.htm
rb70383
Postby JimmieD » Thu Oct 17, 2013 5:51 am
Just a friendly warning on new springs...
I bought brand new front spring packs complete from Eaton Detroit Spring when I did my Cummins swap into Town Wagon. I ordered springs to be 250 lbs higher capacity per side, so 500 lbs total increase in spring rate.
Installed them and they were good for about a month, but sagged out flat with spring shackles up against the frame in 3 months! Complained to Eaton Detroit Spring and their best offer was, "Send them back and we'll take a look at them. If we determine the springs are at fault we will re-arch them." I asked what kind of re-arch, hot or cold, and did they mean they would upgrade the load capacity or something? No, not at all: they would only cold press them, as in adding a few kinks from the press, not replace or re-temper or anything useful. That is, IF they determined they were bad. So I might end up having them determine there was no problem, a crapshoot at best.
Also I would pay shipping back to them, plus shipping to me again, which was as much as I paid for the whole setup in the first place. Long story short - TOTAL SCREWJOB AND NOTHING BUT JUNK!
I ended up pulling the springs off a neighbor's parts truck, a 1950's Chevy pickup, and used them. They were far better than the new Eaton garbage!
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
