I am looking for some info on our vacuum accessories. I found a sensor with a nipple for a vacuum hose that was broken off…This is a sensor with a 2 pin plug located on the driver side fender looks like an 1/8" vacuum line going to it straight off the tee after the boosters check valve. The only issue I've noticed lately is a/c will not switch from the dash vents.
So I'm trying to figure out if this silly little sensor has anything to do with the vents not switching?
If so what is it called?
Any ideas or help is always appreciated.
Not sure if I've set up my profile properly. But in case 92 D-250 I/C A-518, 98% stock, 315,000 miles.
