I broke it.......
I broke it.......
Postby RCCUMMINS89 » Wed Oct 16, 2013 4:45 pm
Ok............so, today I accidentally hit a HUGE log in the road.
After the horrific jolt, I did a once over and everything looked ok. I hop in the truck and notice the steering wheel is now cocked 90 degrees off............ok, broken axle center bolt (been there, done that many times).
Get home, take everything apart...all looks good. :?: When steering wheel is centered like it used to be both wheels are turned to the right.
Call up a local 4x4 guy (and a buddy) he says "ya junked your box".
Thoughts/opinions? I wasn't thinking I would, as I have 3 steering stabilizers on this thing and they take quite the jolting out of everything.
Re: I broke it.......
Postby PToombs » Wed Oct 16, 2013 4:55 pm
Your box may have skipped internally. I have seen the wheel jump thing before, but never experienced it personally. I never heard of that ruining a box, but I guess it's possible. Does it drive ok?
Postby RCCUMMINS89 » Wed Oct 16, 2013 5:08 pm
It is SUPER sensitive to the right............steering to the left is lazy.
It tracks straight, but any sort of an excuse it pulls to the right.
Postby RCCUMMINS89 » Wed Oct 16, 2013 5:42 pm
It's definitely something in the box......
I went out and it now turns quite a bit further to the right than the left.
I'd say that the arm (the one that immediately comes out of the box) possibly just slipped a spline or two.... but due to the odd steering to the right and lazy to the left, tells me it is in the box.
Postby JimmieD » Thu Oct 17, 2013 5:36 am
I haven't looked at these 'newer' Dodge boxes but isn't there a 32 spline connection at top of box, steering box input shaft to steering column shaft, with a clamp or through-pin there? Seems like it could have jumped splines there. I think those splines aren't as deep as the steering arm splines, so it might be the first to slip from impact.
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
Postby ellis93 » Thu Oct 17, 2013 6:17 am
Pull the Pitman arm off the box and I'd bet money you'll find the shafts splines are twisted. Seen this a bunch on different vehicles what were wreaked.
Postby RCCUMMINS89 » Thu Oct 17, 2013 8:48 am
JimmieD wrote:I haven't looked at these 'newer' Dodge boxes but isn't there a 32 spline connection at top of box, steering box input shaft to steering column shaft, with a clamp or through-pin there? Seems like it could have jumped splines there. I think those splines aren't as deep as the steering arm splines, so it might be the first to slip from impact.
It didn't slip there.......
Postby RCCUMMINS89 » Fri Oct 18, 2013 12:50 pm
Ok.............. stuff just ain't right. I went down to the power wash and washed everything clean so that I can tell what I'm doing.
Down and back the truck is just wandering and acting like the alignment is jacked...........so before throwing money at a box I took it down to Les Schwab and had them do a thrust alignment check on it
EVERYTHING was dead nuts on. I have to admit that makes me happy on my frame shortening abilities 8)
But.... box is yarded and the bracket is cracked completely in half. Don't know on the frame there yet or not.
Can we still get the frame to box bracket from Dodge?
Postby ellis93 » Fri Oct 18, 2013 1:08 pm
I need the definition of "yarded" please :lol:
Postby RCCUMMINS89 » Fri Oct 18, 2013 2:05 pm
Broken. Ka-put. Come Un-c*nted. It go good no more.
Postby Black93 » Fri Oct 18, 2013 3:26 pm
Nope, I've tried many dealers all over the country with no luck.
Black93
Postby RCCUMMINS89 » Fri Oct 18, 2013 3:31 pm
Guess I'll have to weld it..... frame is cracked now too.... in three places. Holy balls..........
F'n a cotton...........f'n a
Postby cmann250 » Fri Oct 18, 2013 6:58 pm
RCCUMMINS89 wrote:F'n a cotton...........f'n a
Pep needs new shorts!
Postby RCCUMMINS89 » Fri Oct 18, 2013 7:06 pm
Postby RCCUMMINS89 » Sat Oct 19, 2013 6:03 pm
Put on a new steering box today..... welded up the damner.
So the steering wheel is in the same spot now as it was with the old box....which is the "new" and off position..wtf?
Oh well, I can move a steering wheel.
New box steers VERY firm. I don't like it, I want my old stuff back. :evil: :evil: :evil: :evil: :evil:
