New (reman) steering box, now steering sucks
Re: New (reman) steering box, now steering sucks
Postby RCCUMMINS89 » Thu Oct 24, 2013 5:49 pm
Swapped out the box..........new still stiffer than I'd like but doesn't fight me to the right.
Postby cmann250 » Thu Oct 24, 2013 5:59 pm
Did you wring off the original lines into the box? I'm digging for a P/N or a thread size for when I tackle this job.
Postby RCCUMMINS89 » Thu Oct 24, 2013 6:17 pm
I was able to use off the original lines.
Postby ellis93 » Thu Oct 24, 2013 7:02 pm
viewtopic.php?f=22&t=11065
This might be of help to you,uping the psi might help the stiffness.
Postby RCCUMMINS89 » Thu Oct 24, 2013 7:33 pm
I'll have to look into that.......thanks
Postby PToombs » Fri Oct 25, 2013 5:34 pm
Eric, if that doesn't make a difference, loosen the sheet metal locknut on the input shaft of the box, then back off the input assembly with a spanner about 1/16-1/8 of a turn.
When I did my cab swap my input shaft was rust pitted and leaked all the time, so I swapped in the input assembly from the donor truck. Before the truck was loosey goosey light steering and all over the road. After the swap it was a little tight feeling. I backed it off that much and it steers nice and smooth now. A few years later I was reading in the FSM and saw I adjusted it just like the book said to. :lol:
