Rear Brake Problems in the Cold
Postby 93DodgeCummins » Mon Dec 09, 2013 6:58 pm
I noticed these past few years my left rear brake seems to brake much harder than the others. It has caused the tires to wear faster on that side. That side does leak a little gear oil but I don't think that would make it brake harder. Any ideas on what might be wrong?
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Re: Rear Brake Problems in the Cold
Postby RCCUMMINS89 » Mon Dec 09, 2013 7:01 pm
Any fluid on the brakes will/can make them lock up.
Postby 93DodgeCummins » Mon Dec 09, 2013 7:04 pm
Ok Thanks!
93DodgeCummins
