Transmission bracket diagram
Postby 92cummins89 » Tue Jan 14, 2014 2:54 pm
I pulled my crossmember and bolts and brackets etc tht holds tranny and t case up to clean up and paint b4 I putt the nv 4500 thing is I pulled it bak in August an kinda forgot how it all went back together if anyone has a diagram or pics of wat it looks like underneath would b greatly appreciated.
92cummins89
Re: Transmission bracket diagram
Postby TheSilverBullet » Tue Jan 14, 2014 7:55 pm
I can get you a pic but it should be pretty self explanatory? Just off the top of my head crossmember bolts to the bottom of the frame and then two brackets on each side go from the top of the frame to the crossmember.
Brownie-1990 w250 straight six standard transmission 445k odometer quit in 02 lol
The Silver Bullet-1998 qcsb 12v twins and a 6 speed
Blue bear- 2001 3500 pee pumped 24
TheSilverBullet
Postby 92cummins89 » Wed Jan 15, 2014 8:48 am
Yea tht is but I have a long probably 2 inch wide long piece can't remember where it goes when I get under there I will figure it out just like to see b4 doin it
92cummins89
Postby dazedandconfused » Wed Jan 15, 2014 9:35 am
If I remember right the 2" long piece sits on top of two isolators and that piece bolts to the transfer case or trans. I've not messed with a 4wd but I believe that's how it goes.
Postby 92cummins89 » Wed Jan 15, 2014 10:23 am
Thts the piece tht was messin me up thanks
92cummins89
Postby Black93 » Wed Jan 15, 2014 1:50 pm
Is this what you're talking about?
Black93
Postby 92cummins89 » Wed Jan 15, 2014 2:17 pm
No there's another piece like 3 ft long and has a bunch of bends in it
92cummins89
Postby dazedandconfused » Wed Jan 15, 2014 3:18 pm
Post some pics so we know what you have. Follow the link in my SIG for help posting pics.
Postby 92cummins89 » Wed Jan 15, 2014 6:42 pm
Ok I'll get some Friday when I get home
92cummins89
Postby ccab85 » Mon Apr 14, 2014 7:06 pm
Sounds like the rear crossmember piece of the skidplate, 1 bolt hole on each end, kind of 's' bends on the ends.
91.5 W350 345k stock
ccab85
Postby 92cummins89 » Fri Apr 18, 2014 10:46 pm
Thts it
92cummins89
