Steering issue
Steering issue
Postby 89dudney » Wed Jan 29, 2014 7:45 am
Last night i finished putting my front end back together. I repacked all the bearings and put new seals in it. Everything was set to spec. I went for a test drive and my steering wheel has a catch in it now. When i turn to the left about an 1/8th of a turn, there is a slight catch in the steering. It feels almost like my tire catching on the mud flap, but they have plenty of clearance and I was on flat ground. It only does it to the left. Any ideas of what could be causing the catch?????????? :mad:
I like my truck more than I like 99.9 percent of people...
89dudney
Re: Steering issue
Postby CumminsPower59 » Sun Feb 02, 2014 2:09 pm
Axle shaft U-joint? Put it on stands and pull the wheels. Turn the steering shaft with your hand as you look at everything, might have something moving just enough to bind.
Re: Steering issue
Postby tim curran » Mon Feb 03, 2014 1:55 pm
Steering shaft u joints can go bad. Does it have vacuume hubs or locking? Jack her up and spin that wheel see what it does
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
Re: Steering issue
Postby 89dudney » Tue Feb 04, 2014 9:30 am
I don't know what was causing it. I took the front end back apart and loosened my lock nut on my driver side hub. That seemed to solve most of the problem even though Im not sure how that would play into it.
89dudney
Re: Steering issue
Postby CumminsPower59 » Tue Feb 04, 2014 4:24 pm
What did you set the bearing pre-load at?
