moog front end
moog front end
Postby 93ramrod » Sun Mar 09, 2014 7:14 pm
im looking to replace all major parts in the front end with moog parts. does anyone sell the complete kit including upper/lower ball joints, control arm bushings etc for the 4000lb front axle in one kit instead of trying to source out the individual pieces serparetly?
1993 dodge d250 diesel, 5 speed, ext cab, 355 gears.
93ramrod
Re: moog front end
Postby dazedandconfused » Wed Mar 12, 2014 1:58 pm
You use to be able to get every part on Rockauto but I believe they stopped carrying a lot of the parts.
Re: moog front end
Postby 1992gen1_fan » Wed Mar 12, 2014 4:17 pm
I got a drag link, tierod ends, upper/lower KP rebuild parts, steering gear, sway bar bushings, wheel bearings, spindle bearings ect all from rockauto. All Moog. Some was last year and some late the previous year.
1992gen1_fan
Re: moog front end
Postby boomer » Tue May 06, 2014 10:37 pm
yeah...the full kits are hard to find now....im looking too
boomer
Re: moog front end
Postby Diesel » Sun Jan 04, 2015 10:06 pm
Has anyone found a full quality kit for the D 4000lbs axles? I'm hoping Moog, AC Delco, or Raybestos exists?
1991.5 D250 Intercooled A518
Diesel
Re: moog front end
Postby Diesel » Tue Jan 06, 2015 7:24 am
No kits that I could find. So I just bought all Moog separately. Can in at around $450-500. Didn't buy new springs even though mine are tired. Sorta regretting that now.
Diesel
